End Game (For Now) Streamer/DAC/Preamp? Eversolo DMP-A10
It is an old thread, apologies for resurrecting.
I am very long reader of this forum, coming here for information more usable then flowery "reviews" from some other places.
I have background in engineering so hard data is important and interesting factor for me. But more and more I see this: Someone comes here with his opinion based on his experience. He says - "yes, I know what the blind test is and I performed it -and in my system, in my listening environment - I hear the difference". Then comes self-proclaimed expert and protector of science and objectivity and with zealous fire says - "You are wrong because of science and engineering! of the one holy measurement!". That make me thinking: does this person knows anything about science and engineering or just like to tell others that they are wrong? Does this person ever designed, build and measured any device in professional environment? Honestly, it sounds more like religion than science - especially when main contribution of this person is criticizing others and safeguarding "rules".
Yes, I have, for several years, and specifically on the audio DACs inside a line of consumer A/V products.
Why? because anyone who actually knows anything about practice of science and engineering of mass produced products knows:
- measuring the same product in different lab benches may bring meaningful differences.
- measuring many diffrent samples of mass produces products in the same lab bench may bring meaningful differences.
- one statistical sample of mass produced products does not have any scientifically value.
- not all mass produced devices are QA tested so certain variability of final products characteristics are expected.
- mass produced electronic parts has variability of characteristics both in range of samples and in the same sample depending on environment e.g temperature, magnetic field etc.
- There may be a difference in measurable outcomes between synthetic standardized test and real environment.
- And as for audibility threshold - person listen to his whole system and not this or other device in isolation - using multi-harmonics music and not clean test signals. And some inaudible characteristics may became audible under certain combination of multiple factors in a given system. It happen many times in science and technology - and it happens regularly in mass manufacturing. Thats why manufactures have many revisions of the same product during its lifecycle.
Yes, every single unit from production will measure slightly different, and even every single measurement from a different measuring device could be slightly different.
The only difference that could be enough to make an audible difference is simply output levels, which can easily vary by +/-5% and maybe even +/-10%. That's why it was brought up earlier that precise level matching is necessary (precise generally meaning to within about 0.1dB). The other slight variations one would measure in frequency response, distortion, noise, etc, would all go from inaudible to also inaudible.
Here is the problem with that thought process.
Here is a problem I see with that thought process.
1. You judged OP by comparing the measurements of random other sample of his device without objective knowledge about how his sample measure. You don’t know what level of difference in sound characteristics he personally detected in his system.
2. No one mentioned actual distortion here. The are other audio signal characteristics that may - when combined with other devices in one audio chain - lead to perceived sound difference.
The perception of sound emerges from the interaction of all these signal characteristics of all components in given system, not from any single parameter of a single device.
That’s why systems build from precisely paired components may have other sound characteristics then once build with random components.
Anyway, it is end of topic for me. I did not post to argue but to highlight arrogant attitude of some people here towards newcomers, which makes this valuable place to be seen as toxic by many.
Thank you for your comment. Not argue here. I do not want to repeat myself and spam this topic more then it is necessary, so - if interested - please see my answer in post above.
He did allow this as a possibility, as seen in his post #50 https://www.audiosciencereview.com/...ac-preamp-eversolo-dmp-a10.58252/post-2372886
where he wrote:
"The only way you are hearing a difference in a blind test with these two devices is if one - or both - of the items in your posession are not meeting the measured performance of the one tested here, and by a huge margin - or if the controls of your blind test are inadequate."
And in post #52 in this thread, where he wrote:
"It is possible - but it would be disappointing if the A10 failed to meet the performance of the A8 by 10's of dBs - probably of the order of 30dB or more for it to be feasibly audible for the vast majority of people. It would also mean that the £3500+ device was performing significantly worse than a £150 topping DAC."
What audio signal characteristics are you referring to? We're dealing with DACs, with low output impedances, driving preamps or amps with high input impedances (ie, low source impedance into high load impedance). There is minimal interaction or need for "precisely paired components," well, except perhaps in cases where one or more of the components are poorly designed (such as a DAC with a high output impedance and an amp or preamp with a low input impedance, or a DAC with a really high output level paired with a preamp that clips at such levels.....In other words, again, poorly designed equipment.
Competently designed random components are intentionally designed to remove any need for precisely pairing components. They are designed to interact properly with any other competently designed product.
I allowed for that in *this* statement (bold added here):
Effectively in order for one of his devices to be audibly difference the performance degradation would have to be so bad, it could be considered broken. Not impossible - but highly unlikely.
(EDIT - as also pointed out by @Beave )
Much more likely that the controls in whatever (undocumented) blind test he carried out were inadequate. It is notoriously difficult to get that right - especially in the sort of quick informal tests we tend to do on our own.
So enough of that - I'm not further interested in a rehash of a two month old conversation with someone who was not involved at the time.
Have a look around - see if you can get a feel for the types of device to device varation you might expect - and how audible those can be. But here is a hint. If you purchased an amp with a specified gain of 25dB, you wouldn't expect devices to differ by more than a fraction of a dB from that. If it was out by a dB you might be thinking it was failing to meet it's spec. So why would you expect the designed for noise - or distortion - device to device variation to be so much greater. The same component and build tolerances that might impact amp gain - will equally apply to other characteristics of noise and linearity. And if THD+N varies by only 1dB or even 7 times that at 5dB from a starting point of already inaudible - those differences are also unaudible.
And - as I gave you the link to the Klippel test you will find it informative to discover just how inaudible even relatively large amounts of distortion can be - try it - I think you'll find the results surprising.
Yes, just after couple of patronizing comments. This is a reason for my initial post. Validity of arguments of either side is another story.
Competently and intentionally designed components still may show statistical variability when observed in mass scale in countless combinations in real life environment - outside of manufacturer or internet user lab.
Objective examples from my own profesional experience (background in signal processing and transmission in telecommunication, decades of experience working with data, analytics, modeling in various industries):
1. As a result of collecting data from hundreds of thousands internet connected customer electronics devices, global manufacturer implemented multiple changes to its, otherwise competently and intentionally designed devices, due to unexpected behaviors detected in some combination with other devices. Effect of mass scale and complexities of real life environments.
2. Analyzing data from many production cycles and modeling of complex manufacturing process revealed that very precisely manufactured device (Pharma), in this specific combination of the line and environment variables, works outside of otherwise stable and manufacturer guaranteed parameters. Optimal setting of parameters for this specific production process needed to be adjusted to value outside normal for this kind of devices.
Look, I am coming here for data which helps me to make decisions and learn more about things I love - from information and experiences of other people. It is important data point - one of many. But my experience tells me that religiously following one measurement of one or two parameters in one lab environment cannot be used for judging other people real life experiences with their samples of mass produced device used in complex system and environment. There is a reason why manufactures often says "assuming this and that" or "only valid in reference design" in technical documentation - because they are very well aware about complexities and statistical variability of its mass produced devices outside a test lab. And bad batches are not uncommon.
And I agree, very likely the perceived difference reported by OP may be due to either misconfiguration or some malfunction. But you cannot tell someone - "You do not hear what you hear" without knowing his particular situation. It is, imho, simply not objective and arogant.
Again, I do not challenge your statements - we just see the same data from a different perspective - both objective, from my point of view. Thank you for an interesting discussion.
Anyway, I am looking forward to reading about experiences with T8. I would like to buy it - not because it will be better than my current setup - just because I like good looking and over-engineered devices. I think Archimago is spot on with this article: https://archimago.blogspot.com/2025/10/the-luxury-of-sound-and-time-audiophile.html
EDIT: various typos and language mistakes.
What does your experience tell you about the reliability of human subjective uncontrolled perceptions of their experiences when trying to obtain scientifically valid information?
I suggest you put me on ignore, then you won't be subjected to any further comments from me.
Apparently you either did not read or ignored what I have written, as your comment make no sense to me. Or you just need to have last word, regardless of sense. Let you have it.
Have a nice life.
Kindly thank you for your suggestion.
My first post. Long time reader of the forum. I have some exceptionally nice gear and speakers.
A couple of years ago I added a Cambridge 851N. I thought it was clean but was never really thrilled with it either. But, it was "fine" for the money. I use Quboz.
Recently, it had started having noise/static coming from one of the channels. Did a bit of poking around on the interwebs and found it's not uncommon. Unfortunately, it's out of warranty so you need to send it in to their U.S. service place. I called and it sounded to me like the solution was to remove and replace a card...no upgrade or actual fix. And the cost was 250, plus shipping both ways. To me they have a known problem they choose not to address. IMHO, that's not a company I want to support.
So, yes, I'm irritated with Cambridge. Enough to go in another direction. Enter the Eversolo DMP-A10. Now time will tell if this thing will last, but this thing sounds so much better! Comparatively, it sounds exciting, and the imaging is really good. Right now, I'm just out of the box and I've yet to do any room correction.
I guess you can call me a "fan boy", but the difference is night and day. I'm really enjoying this unit...enough to come on and post.
Thanks for the great forum.
rich
My current streamer is an AppleTV 4K connected to the AVR, remote via iPad. I don't get the concept of such a huge device equipped with a 6" touchscreen when you are sitting several meters away. Also the cooling fins (for a 16 Watt device in a large metal box?!) make it look less sleek than the cheaper models (personal taste). But even if you consider that all products in this category beyond WiiM Pro/Ultra are essentially jewelry there will be people who pay for this and the illusion of better audio quality.
Only up until Apple TV (3rd generation) is optical audio output included. How is your Apple TV 4K connected to the AVR? Which app/SW? What is the resolution?
Source
Welcome to ASR. You have to test level matched and blind for your results to be valid. This is a good read for newcomers:
And the Cambridge has been measured here.
At 110 Sinad - it is transparent - so won't have a different sound from the Eversolo (assuming any DSP used is the same) in a blind test if functioning correctly.
Unless of course the failure mode of the Cambridge was a gradual increase in noise or distortion, that initially resulted in a "non obvious" degradation in sound quality.
More likely though from the description, it was a sudden failure resulting in "static", and the "night and day" difference just comes from the perceptive bias inherent in listening to a new (and very nice) piece of gear.
Wiim Eversolo ( A-6 and A-8) no difference in SQ, so what’s left, features, aesthetics ( pride of ownership) UI, I will probably get an A-10 if nothing else but to play around with its room correction and sub integration features.
You pay your money and makes your choice, in terms of business there is simply no point for me in stocking the Wiim products even though they are exceptional and I use them here.
The margins on the Eversolo gear on the other hand allow me to send units out for evaluation, optimise people’s systems with their EQ features etc etc.
Did you come to a conclusion regarding room correction? Is the Eversolo (that) much better?
Thank you for your insights.
In my experience with room correction, ‘less is more’ I wouldn’t use the ‘auto’ correction, just measure with REW, use it to create the filters and then only correct the very low bass.
Your words not mine, I have just never been that impressed with ‘auto’ correction starting with Dirac, via Trinnov to the latest crop.
Rew not everyone knows how to use it but you are forced to do so if you want a decent DSP on eversolo.
So this function is pointless, it's useless, as is the fiber except to show off to your girlfriend
REW is simply the best whichever components you use with it.
But you have to be able to use it, I already told you, otherwise you'll do worse than the one on board the Eversolo
There you go,
