End Game (For Now) Streamer/DAC/Preamp? Eversolo DMP-A10
Hi there!
may i please ask how one would control specifically APPLE MUSIC on the A10 via an Android tablet which is at the main listening position, which is around 25-30 feet away from the A10, which would sit on an equipment rack inside an audio visual equipment closet?
thank you in advance.
I have an A8 and an A10. Both are outstanding. I expect neither will measure objectively better than the other, but I do prefer the overall sonic presentation/signature of the A10. They do sound different enough to hear that easily. I’m looking forward to seeing the numbers once someone with the right equipment and skills beyond mine posts a review with proper measurements. My only wants would be Gracenote integration—info and art for rips is inconsistent and I would pay for this if it could be added—and Dirac Live as an available purchasable option just for the fun of it. Basically, it’s perfect for me.
I doubt that very much - at least if the comparison is done properly controlled and blind.
I have. It is true. Just different flavors, neither objectively better than the other, as I said. Let’s wait to see test results or until you’ve done as I have
I have both no difference that I can detect, audibly transparent versus audibly transparent.
OK - I was being polite. Let me say it a different way. :)
The performance of the A8 is audibly perfect with figures for noise and distortion well below what the human ear can detect. We don't have measurements for the A10 - but unless it you are claiming it performs significantly worse than the A8 - then we can assume it is equally audibly perfect.
There is not a cat in hells chance that you - or any other human on the planet - will be able to hear any difference between them if the comparison is properly controlled.
Level matched accurately to 0.1dB with a multimeter - all other gear the same - all DSP on both devices bypassed, same reconstruction filter selected, and blind such that you cannot know what is playing - even with subconscious cues from whoever is doing the switching for you, or (for example) noises from the switching mechanism. (normally that means double blind).
Welcome to the forum by the way. :p:cool::)
The A8 and A10 have the same 2.1v/4.2v output but yes level matching to .1dB
You’re entitled to your opinion, I was simply stating mine. I have no doubt that they will both (or all three) measure sonically perfect. What I am saying is that the two components still sound different enough through my system to have different sonic signatures. I was not trying to start an argument or even to say one is better than the other. I have tested both double-blind and level matched and also by running one for days then switching for days then switching back—same everything except the Eversolo. I stand by my conclusion and think both the A8 and A10 are keepers. I have not tried the A6 or A6 ME. You can talk about cats or hell all you want. Thanks for the welcome.
OK - I don't want an argument either - but I am going to stress the point. The foundation of this site is the science and engineering of audio. It is important that we stress this so that others are not misled by misinformation.
The only way you are hearing a difference in a blind test with these two devices is if one - or both - of the items in your posession are not meeting the measured performance of the one tested here, and by a huge margin - or if the controls of your blind test are inadequate.
I suspect the worst case device to device tolerance is quite likely to exceed 0.1dB. Especially between different models.
I understand the mindset of the site. It’s the reason I am on it and reading the tests. I also know how to do a double-blind correctly. Let’s wait to see what the differences are in the measurements before we get to a discussion on whether the sum of those could possibly result in some difference in sonic characteristics. I’d be interested in that.
It is possible - but it would be disappointing if the A10 failed to meet the performance of the A8 by 10's of dBs - probably of the order of 30dB or more for it to be feasibly audible for the vast majority of people. It would also mean that the £3500+ device was performing significantly worse than a £150 topping DAC.
I think your understanding about what differences in measured performance might lead to sound differences is incorrect. Let’s leave it a that and move on.
We get dozens of people a month here thinking the same thing. So far none of them have been able to provide a shred of viable evidence to support that thinking.
Leave it at that? What? I would really like to hear more about what you suspect is erroneous with regards to measured performance and what is audible. It doesn't have to be an argument, we can all learn from this discussion.
So, you’re saying that the only possibly audible difference in any component is a 10db - 30db or greater difference in what? SINAD? Nothing about anything else can result in any sonic difference? I wish you the best of luck.
this might help:
And for pretty much everyone - the lenient thresholds will be valid.
If you're 18, or a bat - you might need the strict thresholds to be the limit.
It is an old thread, apologies for resurrecting.
I am very long reader of this forum, coming here for information more usable then flowery "reviews" from some other places.
I have background in engineering so hard data is important and interesting factor for me. But more and more I see this: Someone comes here with his opinion based on his experience. He says - "yes, I know what the blind test is and I performed it -and in my system, in my listening environment - I hear the difference". Then comes self-proclaimed expert and protector of science and objectivity and with zealous fire says - "You are wrong because of science and engineering! of the one holy measurement!". That make me thinking: does this person knows anything about science and engineering or just like to tell others that they are wrong? Does this person ever designed, build and measured any device in professional environment? Honestly, it sounds more like religion than science - especially when main contribution of this person is criticizing others and safeguarding "rules".
Why? because anyone who actually knows anything about practice of science and engineering of mass produced products knows:
- measuring the same product in different lab benches may bring meaningful differences.
- measuring many diffrent samples of mass produces products in the same lab bench may bring meaningful differences.
- one statistical sample of mass produced products does not have any scientifically value.
- not all mass produced devices are QA tested so certain variability of final products characteristics are expected.
- mass produced electronic parts has variability of characteristics both in range of samples and in the same sample depending on environment e.g temperature, magnetic field etc.
- There may be a difference in measurable outcomes between synthetic standardized test and real environment.
- And as for audibility threshold - person listen to his whole system and not this or other device in isolation - using multi-harmonics music and not clean test signals. And some inaudible characteristics may became audible under certain combination of multiple factors in a given system. It happen many times in science and technology - and it happens regularly in mass manufacturing. Thats why manufactures have many revisions of the same product during its lifecycle.
I have a lot of respect from job done by Amir and other people sharing their measurements here. The information they provide is priceless. But I cannot understand why this or other particular measurement is a holy source of true and any deviation is treated by same people as heresy. It is not scientific and not objective.
I am aware that it's my first post and I may be either ignored or deleted - especially when criticizing "Forum Donor". And I not going to follow on this topic, regardless of results. Usually I do not post on forums but this kind of behavior is more and more common here and it works against the great job of other people here.
Edited: typos and errors.
Here is the problem with that thought process.
As I stated above - for such problems to become audible to more than just a few people in real-world listening, the defects are going to need to get - in the order of 30dB worse. That is - distortion, or noise are going to have to increase something like 30 times - much more, for most people if we are talking about distortion. Not the few percent you might see from component tolerances, or device-to-device variation, or mass-produced variability.
(Don’t believe me? Test yourself to see what level of distortion you personally can detect in your real world listening)
"Forum donor" doesn't buy me any special privileges - nor does my "title" which is simply a measure of how much of my time I've spent (wasted?) here - so you are safe from any sanctions - as long as you are not actively trolling - or otherwise contravening the rules you signed up to when you joined.
Welcome to the forum, by the way.
