There are two things I'm unclear about.
1) The benefit of leaving an air gap behind absorption panels. I have 50cm to play around with (at least on the front and back walls). I can fill that with 50cm of rockwool, or do some combination of rockwool and air gap (25-25, 30-20, etc). Assuming I don't learn something that makes me opt for some sort of membrane-absorption panel thing, is there a benefit to having an air gap as opposed to stuffing the entire allotment with rockwool?
2) Is there a maximum absorption depth beyond which you get minimal returns? Using the calculator at
http://www.acousticmodelling.com/8layers/porous.php, it seems that 40cm seems to be the upper limit, and adding more, even a metre of absorption, gives no additional bass absorption. Is this because of some exponential increase in the amount of absorption necessary, or is the calculator broken?
