Enable Air play and Spotify Connect via Wireguardserver in Openwrt
Jajabinx
Hey there
I have recently been successful in enabling a remote WireGuard access to my network in my openwrt router. Now I plan to only use WireGuard via mobile network to have VPN and home network access from anywhere from my mobile device. I have a nice stereo setup in my living room with an RPi4B that runs Moode Spotify with a DAC and 2 nice KEF LS50 loudspeakers. I'm listening to music via Spotify in highres here. I have an Android device, my wife has an iPhone...
The moodeaudio machine appears to remember the last credentials that have been used for remote control when using Spotify connect. It wont work if i use another device connected to wireguard, neither if I try to remote via airplay using my wife's IPhone. She uses the stereo regularly. Everything works if we login to my openwrt wifi. Now I want to reduce the amount of electromagnetic noise in my home so id like to only use our mobile network at home that needs to have up anyways and disable the homewifi. As I mentioned up I configured a wireguard tunnel that connects over my ISP router to my openwrtrouter so we are connected with our homenetwork.
Here is how my system looks like:
Code:
ubus call system board
"kernel": "5.15.167",
"hostname": "OpenWrt",
"system": "ARMv7 Processor rev 1 (v7l)",
"model": "Linksys WRT3200ACM",
"board_name": "linksys,wrt3200acm",
"rootfs_type": "squashfs",
"release": {
"distribution": "OpenWrt",
"version": "23.05.5",
"revision": "r24106-10cc5fcd00",
"target": "mvebu/cortexa9",
"description": "OpenWrt 23.05.5 r24106-10cc5fcd00"
root@OpenWrt:~# cat /etc/config/network
config interface 'loopback'
    option device 'lo'
    option proto 'static'
    option ipaddr '127.0.0.1'
    option netmask '255.0.0.0'
config globals 'globals'
    option ula_prefix 'fd7f:0959:af62::/48'
config device
    option name 'br-lan'
    option type 'bridge'
    list ports 'lan1'
    list ports 'lan2'
    list ports 'lan3'
    list ports 'lan4'
config interface 'lan'
    option device 'br-lan'
    option ipaddr '192.168.3.1'
    option netmask '255.255.255.0'
    option ip6assign '60'
config device
    option name 'wan'
    option macaddr 'xxxxxxxxxxxxxx'
config interface 'wan'
    option device 'wan'
    option proto 'dhcp'
    option peerdns '0'
    list dns '194.242.2.3'
    list dns '194.242.2.9'
    list dns '103.86.96.100'
config interface 'OPENVPN'
    option proto 'none'
    option device 'tun0'
config interface 'wgserver'
    option proto 'wireguard'
    option private_key 'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx'
    option listen_port '55443'
    list addresses '172.22.22.1/24'
config wireguard_wgserver
    option description 'Husband'
    option public_key 'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx'
    option private_key 'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx'
    option route_allowed_ips '1'
    option endpoint_port '55443'
    option persistent_keepalive '24'
    list allowed_ips '172.22.22.2/32'
    option description 'Wife'
    option public_key 'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx'
    list allowed_ips '172.22.22.3/32'
root@OpenWrt:~# cat /etc/config/firewall
config defaults
    option input 'REJECT'
    option output 'ACCEPT'
    option forward 'REJECT'
    option synflood_protect '1'
config zone
    option name 'lan'
    option input 'ACCEPT'
    option forward 'ACCEPT'
    list network 'lan'
config zone
    option name 'wan'
    option masq '1'
    option mtu_fix '1'
    list network 'wan'
config rule
    option name 'Allow-DHCP-Renew'
    option src 'wan'
    option proto 'udp'
    option dest_port '68'
    option target 'ACCEPT'
    option family 'ipv4'
config rule
    option name 'Allow-Ping'
    option src 'wan'
    option proto 'icmp'
    option icmp_type 'echo-request'
config rule
    option name 'Allow-IGMP'
    option src 'wan'
    option proto 'igmp'
config rule
    option name 'Allow-DHCPv6'
    option src 'wan'
    option proto 'udp'
    option dest_port '546'
    option family 'ipv6'
config rule
    option name 'Allow-MLD'
    option src 'wan'
    option proto 'icmp'
    option src_ip 'fe80::/10'
    list icmp_type '130/0'
    list icmp_type '131/0'
    list icmp_type '132/0'
    list icmp_type '143/0'
config rule
    option name 'Allow-ICMPv6-Input'
    option src 'wan'
    option proto 'icmp'
    list icmp_type 'echo-request'
    list icmp_type 'echo-reply'
    list icmp_type 'destination-unreachable'
    list icmp_type 'packet-too-big'
    list icmp_type 'time-exceeded'
    list icmp_type 'bad-header'
    list icmp_type 'unknown-header-type'
    list icmp_type 'router-solicitation'
    list icmp_type 'neighbour-solicitation'
    list icmp_type 'router-advertisement'
    list icmp_type 'neighbour-advertisement'
    option limit '1000/sec'
config rule
    option name 'Allow-ICMPv6-Forward'
    option src 'wan'
    option dest '*'
    option proto 'icmp'
config rule
    option name 'Allow-IPSec-ESP'
    option src 'wan'
    option dest 'lan'
    option proto 'esp'
config rule
    option name 'Allow-ISAKMP'
    option src 'wan'
    option dest 'lan'
    option dest_port '500'
    option proto 'udp'
config zone
    option name 'OpenVPN'
    option masq '1'
    option mtu_fix '1'
    list device 'tun+'
config forwarding
    option src 'lan'
    option dest 'OpenVPN'
config redirect
    option dest 'lan'
    option target 'DNAT'
    option name 'Force DNS'
    option src 'wan'
    option src_dport '53'
    option dest_port '53'
config rule
    option name 'Allow-55443'
    list proto 'udp'
    option src 'wan'
    option dest_port '55443'
config nat
    option name 'SNAT-WGserver'
    list proto 'all'
    option src 'lan'
    option src_ip '172.22.22.0/24'
    option target 'MASQUERADE'
config include 'pbr'
    option fw4_compatible '1'
    option type 'script'
    option path '/usr/share/pbr/firewall.include'
config zone
    option name 'wgserver'
    list network 'wgserver'
config forwarding
    option src 'wgserver'
    option dest 'lan'
config forwarding
    option src 'lan'
    option dest 'wgserver'
config forwarding
    option dest 'wan'
config forwarding
config forwarding
    option dest 'lan'
config redirect
    option dest 'lan'
    option name 'Spotify Connect'
    option src 'wan'
    option src_dport '4070'
    option dest_ip '192.168.3.141' ---- IP of RBP with Moode Audio
    option dest_port '4070'
config rule
    option name 'Allow-mDNS-AirPlay'
    option dest 'lan'
    option proto 'udp'
    option dest_port '5353'
config rule
    option name 'Allow-AirPlay-UDP'
    option dest 'lan'
    option proto 'udp'
    option dest_port '7000-7100'
config rule
    option name 'Allow-AirPlay-TCP'
    option dest 'lan'
    option proto 'tcp'
    option dest_port '3689 5005'
config redirect
    option dest 'lan'
    option src 'wan'
    option src_dport '3689'
    option dest_port '3689'
    option name 'Airplay'
    list proto 'tcp'
config redirect
    option dest 'lan'
    option name 'AP'
    list proto 'udp'
    option src 'wan'
    option src_dport '5353'
root@OpenWrt:~# cat /etc/avahi/avahi-daemon.conf
[server]
allow-interfaces=br-lan,wgserver
use-ipv4=yes
use-ipv6=no
check-response-ttl=no
enable-dbus=no
[publish]
publish-addresses=yes
publish-hinfo=no
publish-workstation=no
publish-domain=yes
publish-aaaa-on-ipv4=no
[reflector]
enable-reflector=yes
reflect-ipv=yes
reflect-filters=_spotify-connect._tcp
[rlimits]
#rlimit-as=
rlimit-core=0
rlimit-data=4194304
rlimit-fsize=0
rlimit-nofile=30
rlimit-stack=4194304
rlimit-nproc=3
I have now been trying to workaround for about a week but can't figure out how to fix this. I could imagine the problem to be due to the different networklayer: My homenet that is generally connected via Ethernet is contained in 192.168.3.x, the Wireguardserver generally gives IP within 172.22.22.x/32. To be honest I'm not sure how I would integrate the wireguard server to give static leases within 192.168.3.x, nor do I know if that makes sense. Does anyone here hav e an idea how an iPhone and andoidphone will be able to remote control Spotify in that stereo using wireguard?
Thanks in advance and Best Regards
Jajabinx
