hi,
i ordered a emotiva wireless sub setup (1 transmitter, 2 receivers), but i didn't really think it through.
the problem is, i run two setups (audio vs ht) from the same front speakers. i also use the same sub. i have peq on both setups to deal with the one sub. i just use either line in for whatever setup i'm running at the time, with a simple two setup switcher for the mains.
i also just got another sub coming to try and even out some modes and nulls in the bass response.
but with only one transmitter, i've screwed myself.
i guess my question now is, can i get another transmitter to hook into the ht receiver and use the same two receivers i'm using in the audio setup? i know one of them will be too far away for an rca cable. the wife doesn't want a cable running 20 feet along the baseboards...nor do i.
will 2 transmitters operate the two sub receivers independently? with the emotiva wireless system, that is.
thanks for any help.
