Emotiva RMC-1+ AV Processor Review
Rate this AV Processor:
    Votes: 195 88.2%
    Votes: 20 9.0%
    Votes: 2 0.9%
    Votes: 4 1.8%
This is a review and detailed measurements of the RMC-1+ 16 channel Audio/Video Processor for home theater applications. It was kindly drop shipped by a member and costs US $5,499.
RMC-1+ 16 Channel Dolby Atmos & DTS X Cinema Processor Audio high-end review.jpg
The design language follows previous generation. I like all the bits/bytes info on the left and large volume display. The center control is actually a fancy, 4-way joystick -- something I figured out after reading the manual (and not being able to navigate the menus without). I guess it was too expensive to redo the labeling on the front panel to indicate it is the "1+" instead of the previous generation. Fortunately the back panel states it so:
RMC-1+ 16 Channel Dolby Atmos & DTS X Cinema Processor Audio high-end  balanced back panel rev...jpg
This is a lot of channels. I like the high quality RCA outputs even though they likely will never get used. What is with that tuner section? Who would listen to radio in a home theater? There is even a phono stage with programmable loading (which I forgot to test).
Speaking of testing, my Intel GPU connected fine to the RMC and produced video and seemingly sound. But it would not gen up an audio interface in Windows as it normally does. After much struggle, I gave up and used Toslink for testing. I am pretty sure it produces near or identical performance to HDMI.
I left the unit in standby mode and was surprised to feel that it was fairly warm with a number of green LEDs on in the back board. Even the back panel was warm when I tried to remove the XLR cables! It is not hot mind you but I expect standby to be a low power state. I suspect they are keeping a lot of systems on for faster turn on.
Emotiva RMC-1+ AVP Measurements
I configured the unit to be in Reference Stereo. The manual says practically everything other than volume control is bypassed. This as you will see later, was not correct. Here is our dashboard with Volume set to 0 dBFS for front left and right channels:
RMC-1+ 16 Channel Dolby Atmos & DTS X Cinema Processor Audio Measurements.png
That sharply rising low frequency noise was a puzzle. I looked at past Emotiva reviews and found one unit that showed the same behavior. So I continued testing until I got to frequency response. To my surprise, there was a high pass filter in effect! Turns out the default speaker setting is "Small" and setting that, will turn on a crossover, contrary to what the manual says for Reference Stereo. I turned that off and went back and re-ran the dashboard:
RMC-1+ 16 Channel Dolby Atmos & DTS X Cinema Processor Audio speakers large Measurements.png
That hump is gone. But question remains: why would bass management cause that sharp increase in low frequency noise? Seeing how most people would use the unit in that manner, the first measurement is more relevant to its usage. Still, let's give it the benefit of doubt and rank it based on the second measurement:
Very disappointing. The issue is rising noise and distortion starting at just 10 kHz.
I thought I ran the dynamic range test but now can't find it. You can see it implicitly in this very poor showing in IMD test:
RMC-1+ 16 Channel Dolby Atmos & DTS X Cinema Processor Audio IMD distortion Measurements.png
I don't think I have ever tested any DAC with such high level of noise in IMD test!
Here is the output vs distortion:
RMC-1+ 16 Channel Dolby Atmos & DTS X Cinema Processor Audio distortion and noise vs level Mea...png
So best not to crank up the volume past 0 dB unless you really need it. You get a couple more volts but give up even more noise performance.
Linearity is not good but this happens in fair number of AV products:
RMC-1+ 16 Channel Dolby Atmos & DTS X Cinema Processor Audio Linearity Measurements.png
Frequency response is fine:
RMC-1+ 16 Channel Dolby Atmos & DTS X Cinema Processor Audio Frequency Response Measurements.png
But filter attenuation is not:
RMC-1+ 16 Channel Dolby Atmos & DTS X Cinema Processor Audio filter Measurements.png
Wideband THD+N vs frequency is horrid:
RMC-1+ 16 Channel Dolby Atmos & DTS X Cinema Processor Audio distortion vs frequency Measureme...png
Digging in, we see that the cause is not just ultrasonic, but also in-band as we detected earlier:
RMC-1+ 16 Channel Dolby Atmos & DTS X Cinema Processor Audio wideband 1 kHz tone Measurements.png
I tested noise on power on/off and only the former produced such (standby on/off was used):
RMC-1+ 16 Channel Dolby Atmos & DTS X Cinema Processor Audio power on off noise Measurements.png
The RMC-1+ is priced well and feels like a substantial unit with good functionality. Alas, when it comes to measured performance it disappoints in almost every department. It seems no care whatsoever was put in to control and reduce noise. We could argue about audibility of distortion but noise, when wailing from 16 channels, could become bothersome. I know the company has measurement gear and has origins in high performance audio. Shame it has lost its roots this way.
I can't recommend the Emotiva RMC-1+.
Reserved for @RickS to kindly post the specs.
SPECIFICATIONS
DECODING AND PROCESSING MODES
Digital Decoding Modes
Dolby Atmos®
Dolby TrueHD
Dolby Digital Plus
Dolby Digital 5.1
DTS:X™
DTS:X Pro™
DTS-HD Master Audio
DTS-HD High Resolution Audio
DTS 5.1
PCM-Multi 5.1
PCM-Multi 7.1
Digital Post Processing Modes
Dolby Surround Upmixer (DSU)
Dolby Atmos Height Virtualization
DTS Neural:X upmixer
DTS Virtual:X
IMAX Enhanced (Coming Soon)
Audio Operating Modes
Reference Stereo (purist stereo mode)
Direct Mode (minimal processing; with bass management)
Stereo Mode
All Stereo Mode
FRONT PANEL & ON-SCREEN DISPLAY
Display
OLED (dual blue; high resolution 256 x 60 pixel graphical;
variable brightness)
OSD
Color OSD is displayed over live video, including 4k, 8k,
and 3D sources
(variable transparency; multiple operating modes provide different levels of
information)
INPUTS & OUTPUTS
Analog Inputs
1 pair (stereo) – Reference quality analog audio (balanced;
XLR)
3 pair (stereo) – Reference quality analog audio
(unbalanced; RCA)
Digital Inputs
8 – HDMI 2.1 with Fast Port Switching (FPS), Variable Refresh Rate (VRR), and Fixed Rate Link (FRL)
4 – Toslink optical S/PDIF digital audio
4 – Coax (RCA) electrical S/PDIF digital audio
1 – AES/EBU (XLR) digital audio
2 – USB Type A digital data (for firmware updates and future
enhancements)
1 – USB Type B digital audio (“USB DAC” input)
1 – Ethernet port (RJ-45)
1 – Wifi antenna
Other Inputs
Internal high-performance AM/FM tuner
(antenna connections: FM - “F”
connector; AM - push terminals)
Wired IR remote control input
Analog Outputs
16 channels – Reference quality main analog audio (balanced
XLR)
1 pair (stereo) – analog line level Zone 2 output
(unbalanced)
1 – high quality headphone output (1/8” stereo connector)
Digital Outputs
2 – HDMI 2.1
1 – Toslink optical S/PDIF digital audio
1 – Coax (RCA) electrical S/PDIF digital audio
4 – Independently programmable Trigger Outputs
Expansion Ports (for future expansion modules)
RMC-1+ (rear panel) – 3
ENVIRONMENTAL
Dimensions
RMC-1+ – Unboxed: 17” Wide x 15.5” Deep x 7” High (not counting feet)
RMC-1+ – Unboxed: 17” Wide x 15.5” Deep x 7.525” High (with feet)
RMC-1+ - Boxed: 22" Wide x 19" Deep x 10" High
30 lbs.
User Manual
RMC-1+ User Manual
Firmware
5.3 Firmware & Notes
Dirac Room Correction
Dirac Software Download
Dirac Microphone Calibration
Calibration File Download
Thanks Amir.
Rather disappointing, I always hope for better with Emotiva.
Another new Emotiva test, and more new ways to get it wrong.
Nick
Many years have passed and still they cannot design an AVP properly.... What a shame.
I had one of their 50w amps in my garage replacing my Dad's 79 Yamaha receiver which went to my son. The thing was under powered compared to the Yamaha. I was surprised that Loxjie A30 that took over was $100 less and its 30w spec was so much more powerful and clean. I had to push the Emotiva hard to get volume so it was probably distorting.
Absolutely a reason to not buy Emotiva!
Amen
another Emotiva cautionary tale for people who believe you can actually get "more for less" - and the inevitable engineering mistakes that follow from the manufacturing vendors that take the commission for design / build of the "budget" products, where the "features" are the important issue driven by marketing pressures....
It's a nice looking beast tho' -- guess that was the point after all....
Thanks Amir for testing a A/V reciever once again, it's been a while.
Sad that the results are so dissapointing.
That it doesn't properly show up as an audio device in Windows when connected by HDMI is unforgiveable for a product in this category. This isn't a $500 budget receiver (most of which do show up correctly), it's a halo product costing 10x as much, and I'm sure many users will be looking to integrate an HTPC into a high-end home theatre setup.
Couple that with the really abysmal performance, which might be borderline-acceptable in a budget product but is unforgiveable in a pre/pro at this price and with this feature set, and I had to vote "Terrible". Emotiva needs to get their act together.
This is not a budget product, this is $5,500 and performs worse in every respect than a Denon or Marantz receiver with the amps turned off operating in pre/pro mode - and they cost 1/3 as much.
Marantz has a pre/pro at the same price point ($5500USD) - the AV20 - that beats the pants off the Emotiva in every respect.
Shame on Emotiva, that they are selling a US $5,499 device with a manual that is telling complete nonsense and simply lies!!! :facepalm: This is telling:
Even if I would sell esoteric Orgon—Generators to people, I can give them at least a proper manual!
Hands off!
This shows how much of a deal and opportunity the Monolith HTP-1 was. Had that been championed as one of the best 16 ch processors from 2019 (!) there may have been more sales giving a larger user base for both updates and upgrades.
Though it's most excellent when placed on the floor for keeping doors open on a windy day! But, alas, a $5 brick will do the same.
