Emotiva BasX A7+ 7-Channel Amp Review
Rate this amplifier:
    Votes: 10 5.0%
    Votes: 116 57.7%
    Votes: 73 36.3%
    Votes: 2 1.0%
This is a review and detailed measurements of the Emotiva BasX A7+ seven channel home theater amplifier. It was kindly drop shipped to me by a member and costs US $999.
I appreciated the compact size of the A7+. It is a class AB amplifier with linear power supply but doesn't weigh too much. Just heavy enough to give you a feeling of having bought something of substance. Despite its budget pricing, I was pleased to see balanced inputs:
Emotiva-BasX-A7+-Seven-Channel-Power-Amplifier-Home-Theater-balanced-back-panel-review.jpg
Strangely though, both RCA and XLR are active at the same time. So don't connect both if you only need one.
We have both trigger input and output which is nice. There is also a useful switch to turn off the front panel light, a necessity in dark theaters especially since the default is bright blue LEDs.
There is a row of thick, traditional extruded aluminum heatsink which is a step above most AVRs. However, even half-way through testing, the channels under use were getting toasty. Seems like there are a couple of fans in there to keep things from going too crazy.
Protection circuit never came on despite pushing the amp well into clipping multiple times.
Emotiva BasX A7+ Amplifier Measurements
I focused my testing on Channels 1 and 2. I started with XLR input:
Emotiva BasX A7+ Seven-Channel Power Amplifier Home Theater balanced XLR Measurement.png
The gain is a hair higher than specified 29 dB. I like to see this reduced to 25 dB. As otherwise, it just costs you some SNR without much value. I was able to drive the amplifier to clipping with just 0.9 volt for 4 ohm and around 1.5 volt for 8 ohm. XLR sources are capable of producing higher voltages.
I also tested the above using RCA input. While SINAD was similar, the mains noise actually went down which is backward. I suspect there is a balanced to unbalanced converter.
As is, performance is below average of all amps tested:
But still in competent category.
We can see the cleaner RCA performance in our SNR tests:
Emotiva BasX A7+ Seven-Channel Power Amplifier Home Theater balanced XLR SNR at 5 watts Measur...png
Emotiva BasX A7+ Seven-Channel Power Amplifier Home Theater balanced XLR SNR at full power Mea...png
Frequency response is non-load dependent due to it being class AB topology:
Emotiva BasX A7+ Seven-Channel Power Amplifier Home Theater frequency response Measurement.png
Unlike typical class AB though, intermodulation distortion is the same throughout the audible range:
Emotiva BasX A7+ Seven-Channel Power Amplifier Home Theater Multitone Distortion Measurement.png
Emotiva BasX A7+ Seven-Channel Power Amplifier Home Theater 19 20 kHz intermodulation Distorti...png
Crosstalk was pretty poor:
Emotiva BasX A7+ Seven-Channel Power Amplifier Home Theater crosstalk Measurement.png
I could see this in an AVR but not in an outboard amplifier like the A7+.
Power sweeps show that distortion sets in rather early:
Emotiva BasX A7+ Seven-Channel Power Amplifier Home Theater power 4 ohm Measurement.png
Emotiva BasX A7+ Seven-Channel Power Amplifier Home Theater power 8 ohm Measurement.png
Shared power supply and capable output stage allows the amp to far exceed its specs (125 watts) when driven with 2-channels:
Emotiva BasX A7+ Seven-Channel Power Amplifier Home Theater power 4 ohm max and peak burst Mea...png
This bodes well for when more channels are driven simultaneously.
40 Hz power as a result, is no problem for it either, with just a slight reduction:
Unlike typical class AB amp, we see a knee in distortion that lowers with frequency:
Emotiva BasX A7+ Seven-Channel Power Amplifier Home Theater power 4 ohm vs frequency Measurement.png
Strangely, after power up, performance continued to degrade a bit as the amp warmed up:
Emotiva BasX A7+ Seven-Channel Power Amplifier Home Theater Warm Up Measurement.png
And sadly, there is likely going to be some audible pop on both power on and off:
Emotiva BasX A7+ Seven-Channel Power Amplifier Home Theater power power on off noise Measurement.png
Most of the measurements can be summed as, "not bad." I wish the company would strive to go a step higher to comply with the brand impression they like to have. A bit more focused on closed loop engineering using measurements could get them there.
Based on my subjective likeness of the A7+ packaging, I am going to go ahead and recommend the amplifier.
Combination of price, features, aesthetic, build quality, it's.... fine, which I guess is as good as one can expect from Emotiva these days. As you say in the review, it's a shame they dont' strive for better. A little less noise and distortion, a little less crosstalk, and this could be really good value for the money instead of just "fine".
Thank. Amir, nice review. If I bought one of these I would use it in a 5.1.4 Atmos/DTS-X/Auro 3D system to drive every speaker but the L-R, which I would continue to drive with my Purifi Eval 1. Combine this amp with the Mini-DSP 16, an ATV or an NVidia Shield sending running bitstream passthrough to the miniDSP and you could have a small Atmos system for streaming content complete with Dirac ART but without the crappy AV receiver.
This reminds me of my old Emotive amp: it popped both off and on and the soundstage narrowed vs my Yamaha Receiver.
Measurements look good to me. Power is good, and that’s the important part. Good call pointing out the high gain. Pet peeve of “old school” budget equipment is being afraid to crank it up because the second half of the volume knob is clipping hard. I guess any digital processor worth its salt can set limits but still.
I don’t own a home theater setup but given the issues my dad has had over the years I think I’d be too paranoid to run seven channels out of one unit. Too many times, just one channel has gone bad but that necessitates a trip to the shop and a system out of commission. I think cheap class D stereo amps with a backup probably make more sense.
Teardown see attached file
I'm curious to see the review of the upcoming Alsozone multichannels Pam256 amp by 3E Audio....
Have they fixed their XLR pinouts yet?
@amirm Thanks for the nice review!
One question though: Wouldn't it be more informative if you display the power at 40 Hz as a percentage of the average power? I assume the goal of this graph is to show how well an amp keeps its power at low frequencies compared to its specified power rating?
No. It is a ranking of the power of amplifiers, under sort of an extreme, i.e. 40 Hz. I always wanted such a chart but hadn't collected the data in a spreadsheet. But now I have. :)
If Excel allows me to put both pieces of data on the same bar, I will add it in.
Shame they don’t offer this in a 4ch (7.1) or 8ch (7.x.4 atmos) config, as it would be totally adequate for surround use, with nicer amplification for your LCR.
I always have had a soft spot for emotiva, I hope they are able to take a more objectively optimized position in the market in the near future.
The extreme cost-cutting on such devices is always evident in details—such as the small, open-frame switching power supply—rather than the €4–6, fully enclosed Mean Well or Monsun SMPS units.
I do not believe that the performance measurements for the PAM1xx and PAM2xx will differ significantly from those of the A5/A7. According to 3E Audio's specifications, they are actually identical.
Thanks Amir. I confess to being a little bit disappointed.
I thought multi channel power amps were supposed to be an upgrade for receivers?
@amirm can you do the 5ch power output tests @ 8-ohm ideally with 0,1% THD+N as the unit is lighter so you could take it to upstair/downstairs where you have the device to measure it?! Multichannel amps should be always measured 5-7ch driven. Same test you used to do for AVRs, but sadly for some reason stopped it...
The distortion figures at least, show declining levels with each harmonic, so if I have it right, potentially audible higher frequency odd order levels are well down in fairness (3rd harmonic here is -90dB according to the chart, which is where many highly regarded AB amps were back in the day).
Where the picture rules in an AV system, I reckon this amp will be just fine and channel separation not at all an issue in its intended role ;)
If it get really hot, these 2 fans are not going to do much: moving some air around, helping convection a little (not unlike a woofer with no baffle).
