Geert
- Joined
- Mar 20, 2020
- Messages
- 2,346
- Likes
- 4,814
Or are you implying that DL can also correct for phase error which is literally hard-wired into a passive crossover? If so, sweet!
Much more than that: "If the system is not minimum phase (and this is the case in our normal listening rooms) the frequency response will still be flat, but the impulse response will not be ideal, (exactly how it looks will depend on the phase). In order to get the impulse response correct for a non minimum phase system you need to use a filter that is not minimum phase. What this filter will do is shift certain frequencies in time in such a way that they all arrive at the same time, thereby achieving the desired result".
