Embracing Simplicity in Audio: Anyone Else Skipping Room Correction, Measurement Microphones, and the Like?
sound altering room effects are often coveted on the recording side and I would argue on the playback side by some too
That would be a nice thread. Is there really anyone using these AVR sound effect presets?
I know I don't, although at large gathering, like last night,I sent two channel to surround for background music. Toole said multichannel trumps two channel.
I also keep it simple but not for any dogmatic reason, I just don't have a problem to fix. Not every room has issues.
From my point of view room correction is the best thing ever. I got a used mono system with decent components in 1965 and have been fooling with audio ever since. I'm not an EE or have any professional qualifications but I know what I like and know a volt from an ampere.
The simplicity will come from the advancement in the software and its UX implementation.
Pretty soon we will reach a point where not using it is going to feel more problematic than skipping it.
I can wait until the day comes when I'm convinced from this or that specific solution.
That's also a very good point. Another motto of mine is: Solve the problems where they are.
Indeed I don't have any problems in my listening rooms either.
I don't regard using room eq as incompatible with simple. It's a technical thing I have to learn and then it's done. Or I can automate it with Dirac, Audyssey and things from Genelec or Neumann.
Once it is done, life is simple again.
We have to learn all sorts of technical things to get a good sound at home. Choosing what speakers to buy is much harder than doing REQ. Sorting out room modes and reverberations is much harder. But when it's done it's done and I'm back to simple.
To my mind, some sort of basic room EQ is a much much much simpler process than buying and setting up an endless stream of new gear, listening to it for a period of weeks or months thinking all is good, then gradually starting to think maybe all isn't good and looking for new gear, and so on and so on. Measurements, room correction, having an objective end point...simple in the extreme.
I like simple. Compared to turn tables and tape machines, streaming is the simplest way I've ever listened to music.
Yes, I've been doing that for a long time. Not least because of the access to an almost paradisiacal selection of music. I've been using computer audio ever since it started.
I normally listen in my study every day with studio monitors directly in the near field. I find that relatively neutral and transparent. I've also always had analogue systems with turntables, tubes and horn speakers, which I sometimes enjoy even more.
There's no simple, or correct, answer - as always.
I suspect that the OP's system sounds good in his room. So why not just keep life simple and enjoy the music.
Not all systems and rooms are like this. If there are obvious problems; booming bass, nulls, muffled vocals, distortion then judicious DSP should bring an improvement.
Some speakers have audible shortcomings. Replacements are expensive, a little correction is cheap.
If you just like tinkering, then measurements and corrections are part of the enjoyment. Same goes for the joy of learning.
Luddites won't go near this stuff.
Audiophools won't accept that digital corruption can ever help (purity of the signal path).
Enjoy the music
That is of course well thought out and correctly presented. Have you already gone down this route at home?
What have you done to your system, how did you go about it and what means do you use?
