How does it compare to your 3D printed C notes? Have you done the Mechano23 speaker?
Hello,
I have not built the mechano 23 speakers.
So I am going to preference this by saying that I don't have the ability to take measurements at the moment. We just moved cross country and are staying with my wifes parents while house shopping. So what follows will just be my qualitative opinion (for whatever that is worth.)
Both the C notes and the Emanates sound good to me. They are both very clear through the mid range. Instruments really pop on both. You can hear every little slide and pluck on a guitar.
The C notes are on my work computer with a wiim amp pro and a RSL 10E Sub. The emanates are on my wifes computer and use a wiim amp pro and an audio engine S6 sub. They are replacing her Audioengine HD3's.
There are two main differences I can spot. The first is that the emanates have a 4 inch woofer and the C notes have a 5.25 inch woofer. As a result the C notes just have stronger bass. The emanates don't sound bad on their own but if you aren't running a sub you will notice the difference. But like I said I run subs on both setups and cross over both sets at 80hz. So in my particular case the difference doesn't really matter.
The other difference i notice is the sound stage. Both sets have fantastic imaging but with the emanates someone coughing the background of a live performance really does sound like they are in the background. The C notes you kind of get that effect but just not as clearly as the emanates. Tracks like the live version of Hotel California or Wish you were here by Pink Floyd really stand out on the emanates.
There are other differences but im less confident that they are really there and its not just my brain playing tricks on me. The emanates sound a tad more crisp. IE drums/ strums/ cymbals/ shakers all seam like they have just a tad more punch than the C notes. Like on Billie Jean the shaker is just a tad more prominent and the snare a tad more crisp. But this could very well just be a volume normalization kind of thing.
Overall I would be very happy if I had to live the rest of my life with either set but I would def want the RSL 10E over the AudioEngine S6 for sure. If I were building a new pair I would have to have a good long think about it. The emanates I think are the better pair when paired with a sub. But they also cost 3 times as much and are a pain to build. They use about twice as much filament (they are braced like tanks), the crossover doesn't have a pcb, instead you have a printed plate that holds everything together and just solder legs together. Then getting it mounted in the body is a pain too. You also mount the tweeter to the custom wave guide and then solder the wires to it. Then the same for the woofer to the baffle and then you glue the baffle in after that. If you make a mistake and need to get back inside it will basically mean a reprint because i cant see any way to service the tweeter without cutting the box open.
So while they are better I do have some issues with the build process and future manitainance ability. If you want the best then build the emanates but if you want something that is cheaper but still sounds good then its hard to make the case to justify the cost of the emanates.
