Fidji
- Joined
- Feb 17, 2019
- Messages
- 630
- Likes
- 1,225
ELectrostats are like american [or french] cars.
Not the best in terms of performance, quality, design etc - but there is still something that some people get attracted to ...
E.g. I specifically like "line source" [if this is correct term] type of behavior, where voices and instruments have also "height" and are not confined to tweeter height. All subjecitve stuff.
They absolutely do sound terribly colored [and bright on top] if listened to directly on-axis [and even worse if you do it mono, tried it after reading THE book
] , but this changes a lot with proper placement.
They also hugely benefit if proper EQ is applied to bass/crossover area - active models have built in EQ and also that often mentioned mismatch between woofers and panel is meanwhile solved much better than in the time of Prodigys etc.
