RetroStereo
- Joined
- Mar 11, 2026
- Messages
- 148
- Likes
- 230
I'm biased. However, I'll try to give you an idea of what to expect. Most electrostatic speakers are dipoles whereas most dynamic speakers are not. They require a different mindset as to room placement and treatment. Is it worth the effort and expense? In my opinion, yes.I am new to speakers in general and would like to ask a pretty broad question on whether Electrostatic speakers are worth bothering with over conventional dynamic ones.
I have a lot of experience with headphones. There, electrostatic and planar drivers generally reign supreme over dynamics due to their rock bottom distortion that applies to the entirety of frequency response, including the low end. So even tho they very rarely have a natural bass shelf, you can easily add one with EQ and face no drawbacks because the drivers can take it no problem.
So I wonder if the same rules apply to electrostatic speakers. I looked through ASR and some other sources and couldn't find measurements that would give me a clear answer on this topic.
Looking at conventional speakers however, I have seen that they behave much more eratically than headphones. Many having distortion levels shooting through the roof in many places and pretty much always a sharp bass roll off. With only very few (usually also very expensive) speakers managing to avoid those problems.
Will electrostatic speakers help me combat those issues? Do they share the same technical advantages that electrostatic headphones have over dynamic headphones?
But there are classes of speakers that are also very similar to electrostatic, including ribbon, planar (similar to the headphones) and something called air motion transformers (AMT). All have their place and all can be part of exceptional speaker systems.
Two of the most famous names among electrostatic are Quad and MartinLogan. Both make exceptionally fine products, unfortunately, at exceptionally high prices, too. And because electrostatics are essentially giant capacitors, they can represent a brutal load on amplifiers. For example, my Monolith ESL panels are rated at a nominal 4 ohms; however, as frequencies reach ever higher that drops precipitously to 0.8 ohms at 20KHz and 0.6 ohms at 24KHz. Some amps simply implode, sometimes taking the panels with them. Luckily that is less true today.
Another problem is their sheer size. My panels are 26" wide and 48" tall on top of the enclosure that houses the dynamic woofer. The transition between the panel and it's dynamic partner depends on several factors, but the main one is simply square feet of surface. Mine crossover naturally at 6dB per octave at 125Hz so the woofer must take up the bass slack.
Therein is another problem. ESLs are really, really fast and large dynamic drivers just are not. When the Monolith was introduced, people loved its mids and highs but described its low end as muddy. I've resolved that issue with my monoliths by replacing the original woofers with what are probably the fastest model currently made. ML has also incorporated DSP in most of their top models.
A well designed dynamic speaker can have near vanishing levels of distortion until it is overdriven. It also can generally be driven at higher volume levels than most electrostatics. I haven't found that to be much of a problem. I can easily get neighbor complaint levels of sound from mine.
I really can't tell you that ESLs are for you. For me, I knew that I'd eventually have a pair after I first heard a pair of Dayton Wright XG8 models well over 50 years ago. Are they perfect? No. No speaker is. But I like the way they sound.
