Newman
- Joined
- Jan 6, 2017
- Messages
- 5,106
- Likes
- 7,227
I like to think that engineering without science is like politics without accountability.
Engineering really needs science. Let's walk through an example.
Hypotheses about cause and effect are all very well, but they only become real when we put them to the test. And the test needs to be well designed. If the effect being tested is how it sounds, then the test needs to eliminate non-sonic variables.
These realities don't go away just because you call them "horse crap". Accountability bites.
cheers
Good, because those discussions are more often than not centred on misattribution. Unfortunately, macro type discussions are not immune either.I have to admit I don't put much credence into the more micro type discussions about transducers' properties/behaviors, and seldom give attention to them.
Very cool.As a DIY speaker designer/builder of about every type speaker (except electrostats), I've learned it's easy enough to measure transducers in test jigs and prototypes, to find where pistonic ends and breakups begin, as well as get a grip on polars.
Good move. After all, the why discussion is often corrupted with misattribution stirred in a pot of post rationalisation.(And not care so much about why.. ..just me...I'm curious enough, but simply more interested in find best sound I can, even it through excessive trial and error.)
I had a career as a specialist in that kind of engineering, making sure the outcomes dominate the outputs. Needless to say, I think it's important.I'm all about high-level pragmatic engineering.
YepFrom that vantage point, here is how I see electrostats offering a unique sound, or at least a sound different from conventional baffled & boxed speakers.
First, the well recognized dipole radiation.
Truncated line arrays. One of the worst configurations in all of audio, as already mentioned.Second, and at least as important imo, is that being planars they behave as line arrays in both the vertical and horizontal dimensions.
As long as it isn't truncated by, say, a carpeted floor or a gap to the ceiling.Vertical line array behavior is generally a given. I view it as a big in-room positive, owing to lines reduction in the lobing from floor and ceiling bounce. Highly desirable.
You already know what the correct response is to that last statement.My positive experiences with DIY floor-to-ceiling and tall CBT line arrays, led me to see that is exactly what electrostats/planars are doing vertically, subject to the same line array principles regarding length of line and center-to-center spacings of line elements.
The implied c2c spacing is part of electrostat's different sound I think. The tighter and continuous c2c spacing (especially for non segmented diaphragm), let's the line behave as line for all frequencies down to where length on line becomes controlling. This is a real boon for VHF, where most all more conventional lines can't achieve necessary c2c tightness.
I think horizontal line array behavior is generally viewed as problematic, with attempts to either curve the diaphragm horizontally or segment it into vertical stripes. I still have the original CLS, which can sound awesome on certain material, but are too colored for most tracks. (I really need to break them out of the closet and EQ them.) I also have a pair of Acoustat-X with the high voltage direct drive amps, that use three identical panel segments for horizontal dispersion. Still use these for comparisons, still love them.
...Phase is the last part of the unique sound a think.
And not just a flat phase trace from not having a crossover(s). It's flat no matter where you measure off the diaphragm.
Flat phase can be done for any speaker, at least on-axis. Heck, I've had flat phase on everything I've built, typically 5-ways including sub as a way.
But good ole separated drivers' geometry changes phase off-axis. ...even on my syn/MEHs which have considerably tighter c2c's than conventional designs.
Anyway, my 2c on why I think stats sound a bit unique. My 2$ comment is my ears hear it![]()
Trying to divorce the engineering from the science is a bit like trying to divorce politics from accountability. It leads to terrible outcomes.And let me go ahead and preempt any "sighted listening bias", horse-crap replies.
So science, that's so what.I've owned and used the Acoustat-X for nearly 50 years. (CLS, although less used, for 30 yr) I'm quite used to their looks and size...no romance there folks.
Heck, they are kinda small compared to a number/most of my DIYs. And double heck, I don't give a rat's ass what a speaker looks like.
I experiment so much, with many different DIY designs, and many different processing techniques...FIR and IIR...DIY's all built strictly off transfer functions and impulse Reponses.
I audibly compare DIYs to DIYs, both within same type to across types (syns vs lines vs coax vs conventional, etc), ... and compare to the stats, a couple of Meyer rigs, various old speakers I have...even a pair of 901 series VI hanging in the garage lol.
Yes, all sighted. I say so what. It's is a rare event when I hear something that stands out as a real improvement. When horses for courses is taken into account, even with a real improvement in a particular design, I know it is only good for the particular course the speaker was designed for.
Yep, me too. Under controlled condition listening tests. And that's when they keep on flunking. Which would be near-impossible if your dipole behaviour, line source behaviour, and flat phase behaviour were as significant to preference as your descriptions imply.In the end I care about one thing and one thing only...HOW DOES IT SOUND?
cheers
