Newman
- Joined
- Jan 6, 2017
- Messages
- 5,100
- Likes
- 7,216
....However, when ESLs participate in properly controlled listening tests, they don't do well. ...
See below from NTK and me.I suppose, as proponent of science, you have handy relevant sources and data for your statement.
Yes, and Dr Olive has also reiterated that they haven't found a speaker type yet that is exempt from correctly deducing from Spinorama how they will perform in listening tests. "I have yet to find a case where the sound quality could not be predicted based on the spinorama measurements unless it had sufficiently audible distortion." link...per Dr. Toole, conventional measurements (i.e. spinorama) are equally applicable to panel dipole speakers as to conventional forward firing ones.
Furthermore, Dr Olive has commented that they have put multiple brands of stat and panel speakers in their controlled listening tests and they don't win, and in the case of Martin Logan that's putting it mildly. When challenged that they probably didn't position the MLs optimally, he replied IIRC that they did, and actually tried multiple positions and setups and eventually concluded that the preferred position was outside the room, turned off.
Plus, Dr Toole was asked on ASR for comment on panel speakers including ESL, and he said, "They are just different transducers - different ways of moving air. The diaphragms cannot move very far so to generate adequate sound levels at lower frequencies they need to be large. This makes them directional, especially at higher frequencies. They cannot be enclosed, so they are inherently dipoles, which is a characteristic, not a defect. The diaphragms are very light membranes because the motive forces are not as high as the powerful linear motors in moving-coil transducers. This fact has led a lot of people to think that they can move more quickly, reveal more detail, etc. than "conventional" cones and domes. This is not the case. They also allude to more "open" sound, lacking "boxiness". This also is fantasy.
Conventional anechoic measurements are capable of revealing how such speakers can sound, and there are good and less good examples of the breed. One can easily find examples of panel loudspeakers with audible resonances, disruptive directivity characteristics, limited power handling capability, and so on. In the 3rd edition Figure , Figure 18.1(c) shows a Quad ESL Mark 1, 7.12 shows data on a Quad ESL 63, Figure 18.7(a) shows a Magnaplanar 3.6. The 1st and 2nd editions show a Martin Logan Prodigy as Speaker M in Figure 18.4. In every case the results of double-blind listening tests revealed evidence of what the measurements show." (my emphasis) link
cheers
