I'm not sure if you're just giving me more work to do, or have you actually been drinking the kool-aid coming out of these electrostatic speaker discussions? You haven’t spotted any issues?
I hope neither
I had read the new posts starting a few days ago, and mainly only saw discussions about radiation patterns...that didn't appear to have much if any myth content. I have no clue about the existence or not of segmented delay lines, so no comment there.
When it comes to electrostats radiation patterns, I have pretty strong ideas. I see them as operating as line arrays in both vertical and horizontal dimensions. I think Harry Olson's classic line array work describes them well under that viewpoint.
I was just looking for what you considered to be myth within what was recently discussed.
Must say, reading your full myth buster reply, I can't get on board with parts of it.
Stat's vertical beaming is an asset imo. Operating as a line array with the tightest c2c spacing possible for VHF drivers, lets the same sound arrive at any vertical height up to the top of the panels. And limits energy heading to the ceiling for destructive reflected comb filtering.Quad concentric rings. Then there is the myth that the Quad's concentric delay lines meaning that they don't have a beaming problem. Sounds good in theory but in practice the smallest one is four inches in diameter. Now, if someone released a conventional speaker with a four inch tweeter, it would be universally derided, and for good reason, because it would beam like a laser on steroids. But on the Quad it solves beaming? Myth. Sure it helps, but that’s because the untreated stat panel is so bad.
Horizontal beaming...stat's Achilles heel. . A horizonatal line array simply calls for an extremely precise listening position, ime. (Yes, I've turned straight line arrays on their sides)
I've never heard Quads, and know nothing about the rings. I've heard plenty of flat, segmented, and curved panels which all require precise listening focus, some more than others.
I postulate that the vertical line array action (better way to describe than beaming, as beaming only occurs above the height of the panels),
and the same line array action in the horizontal plane that requires precise perpendicular orientation to the horizontal lien,
is what helps give stats their unique sound....along with no crossover, and being a full range membrane.
Sorry, but imnsho this is just flat wrong. Square waves are an excellent test, better and more precise than Fourier analysis really.Square wave perfect. Then we got the hoary old story of Peter Walker showing a perfect square wave coming out of a Quad, and how amazing this means the speaker is. This is a myth and a con job on two levels. First level, that ain't no perfect square wave. Any high resolution examination of the leading edge and the top corners would show grievous irregularities. Sure, plenty of speakers would be far worse, especially in its day, but if someone set out today to specifically design a conventional speaker to play a good looking square wave, the Quad square wave might not 'win'. Second level, there is no need for a speaker to reproduce a square wave well. It's a false goal. Basically, showing off the square wave for a speaker is a showroom stunt. A myth.
A perfect impulse, an excellent flat mag and flat phase transfer function..... produce near perfect square waves...I say near perfect because I've found square waves to be more discerning than FFT
Anyone who disses the legitimacy of square waves, is basically just saying they don't place value on phase and/or time alignment.
The argument about high rez peering into the leading edge and corners is a copout imo...the lack of rez is simply due to the limited bandwidth of audio. Square waves must be evaluated compared to what approaches perfect within the audio bandwidth.
I think open-baffle subs that have more dipole like radiation, cardoiod like to the sides, may make a decent improvement matching stats that radiate front and rear. Dunno, but it makes some sense.Dipole bass and sub. The idea that dipole speakers don’t integrate well with a conventional subwoofer and sound superior with a a dipole subwoofer eg a Ripole. The far more likely reason for one to prefer a subwoofer with diminished LF extension, like a Ripole, is because you are simply not doing a normal subwoofer correctly.
Gotta define room correction. If you mean acoustical, totally agree. If you mean DRC, disagree other than for knocking down modes with a few judicious PEQs.You know what really causes a subjective impression of slow bass? A strong, deep-reaching subwoofer without any room correction.
Lighter than air.
Funny, and yep only a zealous dope would claim that.
fwiw, you seem to sometimes kill both myths and facts together...which puts one leg into the subjective camp as surely as believing myths..BTW I sometimes wonder about being asked to type unnecessary repetition. I get it that myth makers are tireless fans, so are bound to not listen to the realities when stated and therefore just repeat the myths next time the topic comes up, but why don't the myth readers learn when the mythbusting facts are being expounded and stop drinking the kool-aid?
That said, I do appreciate your myth busting work
