Hello, new member here. This forum felt to me like a great place to ask a couple questions about my ECD1. First, here is my setup:
Node 2i, streaming Qobuz > ECD1 Dac > Herron VTSP-3A pre > Odyessy Khartago amp > KEF R11 speakers.
First, a general question, since the ECD1 is 2002 technology, can I do better with current technology for under $2K?
My issue I’m trying to understand and resolve is that when I play hi res music from Qobuz, it sounds as though there’s a blanket covering the speakers. I stumbled onto what corrects this and it is simply to toggle through the 4 input selections on the ECD1 and boom, the sound is clear, detailed and full. It will stay this way until everything is powered off. I have the Audio Clock Trim feature turned OFF on the Node. The ON position did the same thing. I use a coax connection between the Node and ECD1. There are 2 of them, both behave the same.
Interestingly, I found a review from March, 2010 on the ECD1 from hifinews.co.uk. In this review it was stated that;
“the venerable upsampler may operate at 192kHz but will not accept 192kHz inputs, and so both 96kHz and 192kHz source material are reduced to a -1dB/45kHz bandwidth with a mild +0.1 dB peak at 38kHz.”
I don’t know how important this is or isn’t. But hoping someone here can answer that for me. Perhaps it’s part of the problem I’m describing? Thank you for any comments and or suggestions!
Jeff
Jeff
