Electrical Safety and Electronics Servicing
Audiofire
Denmark
Safety Risks and Hazardous Waste
"The limited energy in capacitors (E = ½ C V²) restricts the duration of the shock, even if there are no circuit breakers to trip. The shock current will be limited by the body resistance, and the duration of the shock will be characterized by the time constant (τ = R C)."[1]
Electronics often carry warnings against opening their enclosures. Even after a device is turned off and unplugged, internal capacitors and batteries can store electric charges. AC causes significantly higher risk of muscular tetany and cardiac arrhythmia than DC, under comparable conditions. Protective devices such as GFCIs or RCDs help mitigate this by rapidly cutting fault current duration. Digi-Key Electronics has calculators for safely discharging capacitors with a resistor that has the required wattage.[2][3][4] Digi-Key Electronics warns against discharging capacitors with a screwdriver, since the resistance near zero produces a high-current discharge instead of a safe RC time constant with a resistor.[5] The resistor power rating is important for capacitors with many joules, based on the instantaneous power P = V² / R. Extra-low voltage (ELV) is defined by contact voltage thresholds of ≤50 V AC and ≤120 V DC, where fault protection might not be needed (IEC 61140). Converting the capacitance and voltage of a capacitor to joules is useful to know whether there is a safety hazard. Stored energy of >1.0 J if ≥100 V and >100 J if <100 V are standardized electric shock or thermal hazard thresholds (NFPA 70E).
Electrical safety thresholds should not be interpreted as universal, physiological safety limits. A capacitor containing several joules or more can be a significant hazard, but the physiological effect of electric shock depends on voltage, current, resistance, duration, frequency and electrophysiological path. The energy initially stored in a capacitor is useful for identifying potentially hazardous circuits, but it does not by itself determine whether a particular discharge will cause ventricular fibrillation. Even a shock that does not cause a severe, physiological effect can trigger a startle reflex. The resulting involuntary movement can cause secondary injuries such as falls, burns or contact with moving machinery. More severe shocks can interfere with voluntary muscle control, making it difficult or impossible to release the conductor. Experimental studies have identified ranges of current in which involuntary muscle contraction can interfere with a person's ability to release an energized conductor. These values are commonly called let-go currents. They are not universal safety limits, since the response depends on varying factors, such as contact resistance, duration and the physical condition of the person.[6]
The electrolyte in capacitors can be toxic, irritating or corrosive. Soldering flux is a considerable problem with inhalation or skin contact, because of asthma and dermatitis. Hazardous lead vaporization requires about 450 °C or higher, which is more than hand soldering temperatures, but lead ingestion from solder should be prevented with hand hygiene. Recommended precautions for electronics labs include soldering fume extraction, safety glasses, gloves and lab coats with ESD protection.[7][8] Common electronics lab waste, such as spent isopropyl alcohol, lead solder dross, flux-contaminated materials and leaked capacitor electrolyte are disposed of as hazardous under environmental regulations (like the EU Waste Framework Directive).[9][10][11]
Electrotechnical Concepts in Practice
"The reader is cautioned against interpreting the differences between the voltage values as a true index of the relative hazard between alternating current and direct current. Current is the proper criterion of electric shock intensity, and the hazard from the proposed reasonably safe voltages would be greatly increased if contact occurred at locations where the skin was lacerated or if local high current densities produced material breakdown of the skin. Currents of the let-go level are more than sufficient to produce very serious burns."[12]
SI (metric) prefixes are used to express physical quantities, for example megahertz (MHz = 10⁶ Hz), kilovolts (kV = 10³ V), milliohms (mΩ = 10⁻³ Ω), microamperes (μA = 10⁻⁶ A), nanohenrys (nH = 10⁻⁹ H) and picofarads (pF = 10⁻¹² F). Electrostatic discharge (ESD) is a significant risk for sensitive components (like transistors and integrated circuits), because electrostatic charge in the kilovolt range often builds up with the triboelectric effect, which can cause dielectric breakdown or junction failure. The human body has very small capacitance C in the picofarad range, so electric charge Q causes very large voltage V = Q / C. The resistivity of blood is approximately 100 Ω cm, and 800 Ω cm for muscle tissue.[13][14] Total impedance of living human beings can electrophysiologically be modeled as approximately 2 kΩ to 4 kΩ, under average AC mains conditions (IEC 60479-1).
Multimeters are used for measuring voltage in capacitors. However, LoZ (low-impedance) mode should not be used to discharge high-energy capacitors. LoZ mode is designed to eliminate phantom voltage caused by capacitive coupling between conductors. Discharging stored DC through a meter can exceed thermistor limits or blow protective fuses. SI units are used for dimensional analysis in equations. In the Yamaha M-2 power amplifier for example, the power supply capacitors are both rated for E = ½ C V² = ½ (22 000 μF) (100 V)² = ½ (0.022 F) (100 V)² = 110 J = 110 W s. Aluminum electrolytic capacitors have a finite service life that depends on varying factors, such as operating temperature, ripple current, applied voltage and construction. Manufacturers commonly specify an expected lifetime under particular operating conditions rather than a universal expiration date.[15][16] Physical stress or severe vibration applied to soldered components can crack solder joints, tear copper pads from the PCB (printed circuit board) or break internal bonds. Film capacitors generally have a very long service life, but their relatively low ESR (equivalent series resistance) can cause circuit instability, such as ringing or oscillation in power supplies and feedback loops without the resistive damping of electrolytic capacitors.[17]
Measurement Technique and Specifications
"For aluminum electrolytic capacitors, the capacitance is measured under the standard measuring conditions of 20°C and a 120Hz AC signal of about 0.5V. Generally, as the temperature rises, the capacitance increases; as the temperature decreases, the capacitance decreases (Fig. 7). With a higher frequency, the capacitance is smaller; with a lower frequency, the capacitance is larger (Fig. 8)."[18]
Capacitance, dissipation factor and leakage current are measured to determine whether a capacitor works.[19][20] Always discharge the capacitor first if required by the measurement equipment. Non-polarized (bipolar) electrolytic capacitors are designed to tolerate AC, but only with the manufacturer's voltage, frequency, ripple current and temperature ratings. Ripple current produces internal heating, primarily through ESR, and power dissipation can be estimated with P = I² R. Excessive heating accelerates electrolyte evaporation or other aging mechanisms, reducing the overall service life. Every 10 °C increase in operating temperature is estimated to shorten the service life of aluminum electrolytic capacitors to half, because of the Arrhenius equation. Aluminum electrolytic capacitors will lose their electric charge with time, but there is dielectric absorption that brings previous charge back, sometimes up to about 10%. Long-term storage of aluminum electrolytic capacitors can increase leakage current, where the dielectric requires reforming, which should be performed with the procedure of manufacturers. If the rated voltage (also called the working voltage) is not applied to the electrolytic capacitor for many years, then the dielectric strength degrades.[21] A discharged capacitor initially appears to have a relatively low resistance before the indicated resistance increases as the capacitor charges from the applied test current, although this test cannot determine precise capacitor conditions.
The standardized measuring frequency for capacitance of electrolytic capacitors is 100 Hz or 120 Hz, at a temperature of 20 °C (IEC 60384-1).[22] Film capacitors are often measured at 1 kHz. MKT, MFP and MKP film capacitors with a rated capacitance ≤1 μF have additional measuring frequencies of 10 kHz or 100 kHz for dissipation factor.[23] When replacing a capacitor, the replacement should normally have the same nominal capacitance and the same or higher voltage rating. An ordinary capacitor should not be confused with an X/Y safety capacitor.[24] This also depends on finding the right temperature rating, ripple current rating, dissipation factor and physical dimensions, including lead spacing for the replacement. LCR meters (or software like Room EQ Wizard) apply an AC test signal. LCR measurements of a component connected to a circuit can be misleading. Verification of specifications also gives an impression of authenticity if an authorized distributor was not used. However, there can still be defects because of the acceptance quality limit (ISO 2859-1 and JIS Z 9015-1).[25] The typical failure modes of aluminum electrolytic capacitors are short circuit, open circuit, electrolyte leakage, increase in leakage current and open vent when heat or internal pressure increases because of excessive operating voltage or ripple current.[26] Bipolar transistors (BJTs) can be tested using a multimeter with diode test mode. A conventional silicon transistor will show a forward voltage drop of about 0.6 V to 0.7 V from base to emitter and base to collector, and open loop (OL) when measured in reverse, while collector to emitter must read OL in both directions.
"A capacitor’s total complex impedance is represented on a real-complex plane as the vector sum of a real component, (the ESR) and a complex (reactive) component representing the ‘ideal’ capacitor that things like ESR mess up in all actual components. The angle between the total impedance and its complex component is called the ‘loss angle,’ and is a figure used to summarize the ratio between the ideal and non-ideal components of a capacitor’s overall impedance."[27]
Soldering Technique and Component Replacement
"The expected life time shall be about fifteen years at maximum as a guide in terms of deterioration of the sealant."[28]
Rosin or resin flux that is halide-free, respectively called ROL0 or REL0 is used because of chemical reactions of halides or other fluxes that are harmful for aluminum electrolytic capacitors or other electronic components (J-STD-004). Eutectic Sn63/Pb37 solder is often the best option for servicing vintage electronics, since restriction of lead in the European Union came into effect for products and spare parts originally placed on the market on July 1, 2006 or later. RoHS restricts certain hazardous substances in products. Polarized components (like electrolytic capacitors and LEDs) must be installed with the correct polarity, since reverse polarity can prevent the component from functioning or cause catastrophic failure. Applying pressure during soldering can cause excessive wear on solder pads. Movement of components during solidification disturbs the joint as it cools, producing a solder joint lacking mechanical integrity.
ELNA states that the sleeves of aluminum electrolytic capacitors should not be considered as an insulation, and that the aluminum case is connected to the cathode terminal through the electrolyte, which has uncertain resistance.[29] Surface tension, wetting and capillary action primarily determine solder adhesion, so plated through-holes can be soldered at a slight angle for better ergonomics and vision. ELNA states that the optimal dwell time during hand soldering is less than 3 seconds for electrolytic capacitors.[30] Pre-applying flux is essential for SMD drag soldering, transfer soldering or rework. However, pre-applied flux is optional for through-hole soldering using flux-cored solder. Oxidation prevents intermetallic bonding, although gold does not oxidize under normal conditions.[31] The soldering iron tip must be tinned regularly to prevent oxidation. The soldering iron tip should be set to at least 30 °C to 50 °C above the liquidus temperature of the solder, to ensure enough heat transfers into solder joints for intermetallic bonding.[32] Nichicon recommends using isopropyl alcohol for cleaning PCBs, although compatibility with electronic components varies. Capacitors directly connected in series might need voltage-balancing (bleeder) resistors in parallel across each one. Otherwise, unequal resistance or leakage current risks imbalanced voltage and overvoltage breakdown.[33]
References
[1] Mark A. Scott. "Working Safely with Hazardous Capacitors". IEEE Industry Applications Magazine (Volume 25, Issue 3, May–June 2019).
https://ieeexplore.ieee.org/ielaam/2943/8685745/8661497-aam.pdf
[2] D. Sculley. RC Time Constant. Tufts University.
https://www.eecs.tufts.edu/~dsculley/tutorial/rc/rc3.html
[3] Digi-Key Electronics. Capacitor Safety Discharge Calculator.
https://www.digikey.dk/en/resources...version-calculator-capacitor-safety-discharge
[4] Digi-Key Electronics. Time Constant Calculator.
https://www.digikey.dk/en/resources/conversion-calculators/conversion-calculator-time-constant
[5] Ashley Awalt. How to Safely Discharge a Capacitor. Digi-Key Electronics.
https://www.digikey.com/en/blog/how-to-safely-discharge-a-capacitor
[6] Charles F. Dalziel. "Effects of Electric Shock on Man". IRE Transactions on Medical Electronics (PGME-5, July 1956).
[7] Lawrence Berkeley National Laboratory. Safe Soldering Work Practices.
https://eta-safety.lbl.gov/sites/default/files/Soldering Guidelines.pdf
[8] Massachusetts Institute of Technology. Soldering Safety and Health Guidelines.
https://ehs.mit.edu/wp-content/uploads/EHS-0167.pdf
[9] Nippon Chemi-Con. Precaution of Capacitor Disposal.
https://www.chemi-con.co.jp/en/faq/detail.php?id=29BFLER
[10] University of Cambridge. Soldering Safety.
https://safety.eng.cam.ac.uk/safe-working/copy_of_soldering-safety
[11] Farnell. Managing Solder Fume Extraction.
https://uk.farnell.com/essential-considerations-for-managing-soldering-fume-extraction-p2
[12] C. F. Dalziel & F. P. Massoglia. "Let-Go Currents and Voltages". Transactions of the American Institute of Electrical Engineers, Part II: Applications and Industry (Volume 75, Issue 2, May 1956).
[13] Herman P. Schwan & Calvin F. Kay. "Specific Resistance of Body Tissues". Circulation Research (Volume 4, No. 6, November 1956).
https://www.ahajournals.org/doi/pdf/10.1161/01.RES.4.6.664?download=true
[14] Stanley Rush, J. A. Abildskov & Richard McFee. "Resistivity of Body Tissues at Low Frequencies". Circulation Research (Volume 12, No. 1, January 1963).
https://www.ahajournals.org/doi/pdf/10.1161/01.RES.12.1.40?download=true
[15] Nichicon. Application Guidelines for Aluminum Electrolytic Capacitors.
https://www.nichicon.co.jp/english/products/pdf/aluminum-e.pdf
[16] Sam G. Parler, Jr. Reliability of CDE Aluminum Electrolytic Capacitors. Cornell Dubilier.
https://www.cde.com/resources/technical-papers/reliability.pdf
[17] Cornell Dubilier. AC Capacitor Application Guide.
https://www.cde.com/resources/technical-papers/ACappGUIDE.pdf
[18] Nippon Chemi-Con. Judicious Use of Aluminum Electrolytic Capacitors.
https://www.chemi-con.co.jp/products/relatedfiles/capacitor/catalog/al-technote-e.pdf
[19] Sam G. Parler, Jr. Selecting and Applying Aluminum Electrolytic Capacitors for Inverter Applications. Cornell Dubilier.
https://www.cde.com/resources/technical-papers/selectinvcap.pdf
[20] Sam G. Parler, Jr. & Laird L. Macomber. Predicting Operating Temperature and Expected Lifetime of Aluminum-Electrolytic Bus Capacitors with Thermal Modeling. Cornell Dubilier.
https://www.cde.com/resources/techn...erating-Temperature-and-Expected-Lifetime.pdf
[21] Würth Elektronik. Afraid of Aging? The Effects of Time on Electrolytic Capacitors.
https://www.we-online.com/catalog/media/o467325v410 SN019_EN_d.pdf
[22] TDK Electronics AG. Aluminum Electrolytic Capacitors: General Technical Information.
https://www.tdk-electronics.tdk.com...2da2adf2b/pdf-generaltechnicalinformation.pdf
[23] TDK Electronics AG. Film Capacitors: General Technical Information.
https://www.tdk-electronics.tdk.com...1513474ba/pdf-generaltechnicalinformation.pdf
[24] TDK Electronics AG. Film Capacitors: Marking and Ordering Code System.
https://www.tdk-electronics.tdk.com...53733752/pdf-markingandorderingcodesystem.pdf
[25] TDK Electronics AG. Aluminum Electrolytic Capacitors: Quality and Environment.
https://www.tdk-electronics.tdk.com...1ab2a2d36b44f51/pdf-qualityandenvironment.pdf
[26] United Chemi-Con. Failure Modes.
https://chemi-con.com/failure-modes/
[27] Digi-Key Electronics. Calculating Capacitor ESR from tan(δ).
https://forum.digikey.com/t/calculating-capacitor-esr-from-tan/2633
[28] ELNA. Aluminum Electrolytic Capacitors.
https://www.elna.co.jp/en/capacitor/alumi/catalog/pdf/0-tech-note_AL_e.pdf
[29] ELNA. Cautions for Using Aluminum Electrolytic Capacitors.
https://www.elna.co.jp/en/capacitor/alumi/catalog/pdf/al_caution_e.pdf
[30] ELNA. Soldering Conditions.
https://www.elna.co.jp/en/capacitor/alumi/catalog/pdf/al_handa_e.pdf
[31] Jim Smith. A Practical Guide to Soldering Flux. Sierra Circuits.
https://www.protoexpress.com/blog/guide-soldering-flux/
[32] Indium Corporation. Soldering 101 — A Basic Overview.
https://www.indium.com/technical-documents/application-notes/download/27/
[33] Nichicon. Plastic Film Capacitors.
https://www.nichicon.co.jp/english/products/pdf_x/Plastic_Film_Capacitors_E.pdf
Supplementary Quotations
"As recycling electrical and electronic devices is good for the environment, the RoHS directive is not applicable to second-hand equipment. Repairing and even upgrading the devices marketed before 1st July 2006 may also be realized with non-RoHS compatible components, insofar as this product is not marketed as new. Products marketed as new products from 1st July 2006 must be repaired with RoHS compatible components."[1]
"Interestingly, products using leaded solder can still be sold, but only if they were introduced before July 1st 2006. In practice, though, this is only a short-term arrangement and will generally apply to only a few products, mainly from small manufacturers. However, the situation gets a little more involved when it comes to spare parts and repairs. Fortunately, the RoHS directive recognises that non-compliant components will be required to maintain 'legacy' equipment, and so permits their production and sale indefinitely — but whether the manufacturers will feel the market is sufficient to warrant their production is another matter!
"Related to all this is the fact that mixing leaded and lead-free solders is really not a good idea at all. So service centres will need to identify which kind of solder is employed in a product and use something compatible when making repairs. Reliability could be adversely affected by lead contamination of a lead-free circuit board, or by mixing lead-free and lead solders on an 'antique' PCB."[2]
"When the lead spacing of a capacitor does not match the hole spacing on your PCB, the capacitor should have its leads formed to avoid exposing the capacitor to excessive mechanical stress.
"The maximum amount of lead stress should be limited to 1.0 Kg in the vertical direction and 0.5Kg in the horizontal direction.
"You should also avoid bending the leads of your capacitor right next to the capacitor body itself - the internal connections from a capacitor’s leads to its actual capacitive material are delicate and can easily be damaged. Leave at least a millimeter or two between the capacitor body and the first bend in your leads to avoid breaking those delicate connections."[3]
"Aluminum electrolytic capacitors are polarized. Make sure that no reverse voltage or AC voltage is applied to the capacitors. Please use bi-polar capacitors for a circuit that can possibly see reversed polarity.
Note: Even bi-polar capacitors can not be used for AC voltage application.
"There are non-halogen types of flux that do not contain ionic halides, but contain many non-ionic halides. When these non-ionic halides infiltrate the capacitor, they cause a chemical reaction that is just as harmful as the use of cleaning agents. Use soldering flux that dose not contain non-ionic halides.
"1) Do not use any fixing or coating materials, which contain halide substance.
2) Remove flux and any contamination, which remains in the gap between the end seal and PC board.
3) Please dry the cleaning agent on the PC board before using fixing or coating materials.
4) Please do not apply any material all around the end seal when using fixing or coating materials.
"(1) Take either of the following methods in disposing of capacitors.
• Make a hole in the capacitor body or crush capacitors and incinerate them.
• If incineration is not applicable, hand them over to a waste disposal agent and have them buried in a landfill.
"(2) When removing a capacitor from the circuit board or when disposing of capacitor please ensure that the capacitor is properly discharged."[4]
"Parts which dissipate heat in quantities of 1 Watt or greater, or in quantities sufficient to damage the laminate shall be mounted with sufficient standoff [ > 1.5mm (0.060 in.) ] and shall be mechanically restrained.
"Parts having conductive cases, which are mounted over printed conductors or which are in close proximity to other conductive materials shall be separated by insulation of suitable thickness, or shall have an insulating jacket/sleeve.
"Exposed ends of leads on straight-through termination shall not be cause for rejection if the PWA is to be conformally coated.
"Parts shall be mounted in such a manner that, at a minimum, the markings are visible in the following order of precedence: polarity, traceability/lot code (if applicable), part value, part number/type.
"Contamination is a reliability concern.
"Parts with damaged seals shall not be used.
"Dewetting is caused when molten solder coats a surface and then recedes, leaving irregulary-shaped solder deposits separated by areas covered by a thin solder film.
"A disturbed solder joint is characterized by the appearance that there was motion between the metals being joined while the molten solder was solidifying.
"Parts shall not be mounted such that they obstruct solder flow to the component-side termination area (pad) or prevent cleaning and inspection.
"Leads shall be cut per engineering documentation and by methods, which do not impart stress to the lead seal or internal terminations.
"Parts shall be mounted parallel to the laminate surface, right side up and aligned to the lands within design and engineering specifications.
"The use of parts with nicks in the component body or termination area is prohibited.
"Poor wetting is an indicator of poor solderability, improper flux or contamination."[5]
"Flow (wicking) of solder along the conductor is permitted. Solder shall not make presence of the individual wire strands indistinguishable.
"Tin the iron tip, while the connection is cooling at room temperature. A small amount of solder should remain on the tip.
"Minimum steps to protect ESD-sensitive devices are:
• Always work at a grounded workstation
• Use only ESD-approved materials
• Handle ESD-sensitive devices only at static-safe workstations
• Always use a conductive wrist strap before handling ESD-sensitive devices
• Use an ESD bag or container to store or carry parts in.
"Hot tinning of solid conductors and part leads should not extend closer than 0.5mm (0.020 inch) to part bodies, end seals, or insulation unless the part configuration and mounting configuration dictate it.
"Cut the lead.
• Straight-through leads may be bent up to 30 degrees from a vertical plane to retain parts during the soldering operation.
• Part leads terminated straight through the PWB shall extend a minimum of 0.51 mm (0.020 in.) and a maximum of 2.29 mm (0.090 in.).
"Position the soldering iron tip so as to touch both the lead and the printed wiring pad at the same time.
"Apply solder to the junction where the iron and lead meet in order to produce a thermal (solder) bridge.
"Touch the solder to the end of the cut lead to cover the exposed copper.
"Add solder as needed to complete the soldered connection.
"Remove the solder; remove the iron.
"The end of the part body must be mounted with at least 0.51 mm (0.020 in.) to a maximum of 1.27 mm (0.050 in.) clearance above the PWB surface. The end of the part is defined to include any extensions such as coating meniscus, solder seal, or weld bead.
"Inspect the solder joints under 4 X to 10 X magnification to the specified requirements.
• Free of flux residue and other contaminants.
• The solder shall wet all elements of the connection.
• The solder shall fillet between connection elements over the complete periphery of the connection."[6]
"At soldering iron temperature, solder will stick to oxides and contaminants to produce a visually acceptable connection. However, the connection lacks an intermetallic bond and the high temperature degrades bonds inside components. The altered bonds change electrical values and shorten component life. In just a few seconds of improper application, a soldering iron can shorten the life expectancy of components by decades.
"The arrival of solid-state components meant that, for the first time, solder was applied directly to the component rather than wires and sockets. In other words, the components were subjected to the soldering heat. And this had profound reliability consequences because heat degraded the component electrical properties."[7]
"No-clean solder paste generally doesn’t require cleaning.
"In reality, no-clean solder paste leaves behind flux with low residue. The reflow process leaves trace amounts of resinous residue, noncorrosive in nature. Present on or around solder joints, the residue can vary in color from amber to transparent. The residue left on the board after reflow depends directly on the solid content in the solder paste, mainly made up of activators, gelling agents, and resins.
"The primary intention for removing the no-clean flux and its residue from the board surface is to prevent interference with signal transmission and malfunction in circuit functioning.
"Numerous no-clean flux removers are available in the market, and their strengths vary."[8]
"Activated rosin fluxes contain small quantities (0.2% to 5%) of organic activating agents. The purpose of these activators is to catalyze the rosin copper oxide reaction so that a better soldering job can be obtained. The catalytic agents do not enter into the reaction and do not cause subsequent corrosion. However, the presence of these activators does impel the rosin (abietic acid) to combine with the copper oxide to form the green copper abietate compound. Copper abietate is not conductive and forms a green insulating coating on copper. Usually the dark rosin residue conceals this normal formation of green copper abietate."[9]
"Electrolytic capacitors are able to survive some transient current abuse, typically more than their metallized film counterparts. As a rule of thumb, for brief ripple current excursions such as several seconds of 2 to 4 times the rated load ripple current, the thermal mass of the capacitor winding will absorb a lot of the extra energy dissipation of such an event.
"For aluminum electrolytic capacitors, dielectric absorption will allow up to 10% recovery of a previously applied voltage. Thus with high-voltage aluminum electrolytic capacitors rebound voltages of 40 to 50 V are possible. While such voltages are not usually a shock hazard, they can certainly cause sparking and even arc damage during installation.
"During charging the voltage on each capacitor connected in series is proportional to the inverse of the actual capacitance, but upon reaching the applied voltage, the steady-state DC voltage that each capacitor approaches no longer depends upon its capacitance at all, instead shifting to follow the inverse of the capacitor’s leakage current.
"Ripple current is the AC current flowing through the capacitor. It’s called ripple current because the associated AC voltage rides on the capacitor’s DC bias voltage as a ripple rides on the surface of water. The ripple current heats the capacitor, and the maximum permitted ripple current is set by how much heat rise can be permitted while still meeting the capacitor’s load life specification. Too much temperature rise will cause the capacitor to exceed its maximum permitted core temperature and fail; even operation close to the maximum permitted core temperature dramatically shortens expected life.
"Don’t exceed the maximum storage temperature while preheating the capacitors [...] Don’t contact insulating sleeve or other plastic parts with a soldering iron or molten solder.
"When gluing, don’t apply glue to the full capacitor circumference, and don’t cover the capacitors’ pressure-relief vent with potting or glue.
"In the case of electrolyte contact to skin, immediately rinse the exposed area with soap and water. If electrolyte contacts eyes, flush for 10 minutes with running water and seek medical attention. If vapors are present, ventilate the room."[10]
"1) A capacitor with more than a certain case size has the pressure relief vent functioning to escape abnormal gas pressure increase.
If gas expels from a venting capacitor, disconnect the power supply of the device or unplug the power supply cord. If not disconnecting the power supply, the device circuit may be damaged due to the short circuit failure of the capacitor or short-circuited with the liquid that the gas was condensed to. It may cause secondary damages such as device burnout in the worst case scenario.
The gas that comes out of the open vent is vaporized electrolyte, not smoke.
2) The gas expelled from a venting capacitor is more than 100°C. Never expose your face to the capacitor. If your eyes are exposed to the gas or you inhale it, immediately flush your eyes and/or gargle with water. If the electrolyte comes in contact with the skin, wash with soap and water."[11]
References
[1] Geert Willems. The RoHS Directive: An Answer to Your Questions. Sirris.
[2] Sound on Sound. Has the EU Directive on Hazardous Substances (RoHS) Impacted Equipment Sales?
https://www.soundonsound.com/sound-...dous-substances-rohs-impacted-equipment-sales
[3] Digi-Key Electronics. Lead Spacing/Bending.
https://forum.digikey.com/t/lead-spacing-bending/435
[4] Nichicon. Aluminum Electrolytic Capacitors.
[5] National Aeronautics and Space Administration. NASA Workmanship Standards.
[6] National Aeronautics and Space Administration. NASA Training Program: Student Workbook for Hand Soldering.
[7] Jim Smith. How to Achieve Perfect PCB Soldering. Sierra Circuits.
https://www.protoexpress.com/blog/how-to-achieve-perfect-pcb-soldering/
[8] Akber Roy. Is It Necessary to Clean No-Clean Flux? Electronic Design.
https://www.electronicdesign.com/in...ush-pcb-is-it-necessary-to-clean-noclean-flux
[9] Kester. Green Corrosion with Rosin Flux?
https://www.kester.com/Portals/0/Documents/FAQs/GreenCorrosion_Global.pdf
[10] Cornell Dubilier. Aluminum Electrolytic Capacitor Application Guide.
https://www.cde.com/resources/technical-papers/AEappGuide.pdf
[11] Nippon Chemi-Con. Precautions and Guidelines (Aluminum Electrolytic Capacitors).
https://chemi-con.com/wp-content/up...ines-for-Aluminum-Electrolytic-Capacitors.pdf
When bending legs on caps I always hold them close to the body with needle nose pliers and bend outside so as not to stress them.
To elaborate, this is done to avoid damaging the seal, which in turn might cause premature failure.
If I think there is a possibility of stored charge in a piece I will be working on, I just poke around with a DC voltmeter and have a look-see. If I find any charge, I use a well-insulated probe to bleed it down through a resistor. It's never a good idea to short the leads of a charged cap together; bleed the charge away though a current limiting resistor to make life easy for the cap.
Do you check for voltage on capacitor terminals or somewhere else?
If cap terminals are accessible to test probes, I look there first; otherwise, I poke around circuits supplied by the voltage on the capacitor.
You are doing it right. Done repairs over more than 50 years I am a practical guy regarding capacitors. Since also repaired electron vacuum tube gear I can say that these loaded caps up to 800V are dangerous when touching the pins, creating a real shock. On silicon power amps the big cans with around 2x 70V need also care. Always unload the charge with a resistor. But the caps in preamps, CD-players such with +-22 V maximum there is no problem regarding electrical shock. Why discharge anyway? If connected by accident to an transistor or IC these can become defective due to overload.
You might want to discharge the low voltage caps in S.S. gear in order to not accidentally connect (short) that residual voltage to a part of the circuit that could be damaged by it when repairing the device.
Updated the dead links that were not on the Wayback Machine
The rest were already on that website. Suggestions for improvement welcome about my servicing notes.
