FiftyTifty
- Joined
- Aug 9, 2023
- Messages
- 38
- Likes
- 7
Problem: When computer off, very quiet white noise from speakers. When computer on, nasty electrical noise when idle. When computer doing heavy work (CPU or GPU, probably power draw related), absolutely awful squealing.
This has been a pain for years, and finally remembered to try out using a USB-C cable to the S.M.S.L D6s I bought after it was recommended. Turns out that didn't fix it.
My setup used to be: Creative Sound Blaster X-Fi Titanium Fatal1ty Pro -> Optical -> Splitter -> (1st) 2x Edirol MA-15Ds -> (2nd) S.M.S.L C100 -> (2nd) RCA 2x Yamaha HS7
Now after trying to isolate possible issues, it's actually worse as: USB-C -> S.M.S.L D6s -> XLR 2x Yamaha HS7
Whereas it doesn't cut through anywhere near as much as: Creative Sound Blaster X-Fi Titanium Fatal1ty Pro -> Optical -> S.M.S.L D6s -> XLR 2x Yamaha HS7
The C100 was an unbalanced dac, and the D6s is a balanced one. No difference in behaviour from either of those. And when connected to the dac via USB, even just moving the mouse causes the speakers to put out an icky grainy sound. It's absolutely awful.
Unfortunately I don't have many plug sockets, and the place I'm in is from the 80s so the wiring probably won't have independent circuits for either pair of sockets. Got so much gear that I have to use a Belkin 8x power socket splitter. 1 for the main pc, 1 for the monitor, 2 for the speakers, 1 for the fibre modem, 1 for the Roland audio interface, 1 for the router, 1 for the USB port splitter, 1 for the streaming server....
Bloody hell I have a lot of plugs being used. Christ.
What's the way forward here? I read something about ground loop isolators but they go into circuitry babble one comment into the threads, which is way over my head. And folk saying that it's unsafe because electricity (basically).
