BigFKahuna
- Joined
- Apr 6, 2022
- Messages
- 64
- Likes
- 67
Best is to know what we are trying to achieve, and why. Caries (cavities) are the result of acid attack on mineralized dental tissue....ie teeth. Typically the acids are the result of an undisturbed bacterial colony residing on a tooth for a period of time, in the presence of a fermentable carbohydrate. Technically, sugar alone does NOT cause cavities. Disturbing the bacterial colonies once every 24 hours is essentially enough to prevent the production of acids that result in demineralization, so the thinking is that brushing (and flossing) once daily will suffice. However, as most people don't get all the nooks and crannies, it is often recommended to brush after every meal in order to get the spots that one misses....problem is that most people tend to miss the same spots when brushing. The bacteria (and dental plaque) must be disturbed mechanically, this rinsing with water alone does not suffice. Rinsing with an anti-bacterial agent helps, sometimes more than brushing for some people. Chlorhexidene being the most effective. Xylitol is very effective at the prevention of cavities, its use in mouthwashes and toothpastes might be more effective than fluoride. To address what another poster said...there are no well designed double blind controlled studies to show the efficacy of fluoride (in drinking water or toothpaste or as an additive...I actually forgot which, might be all).Curious what your take is on the evidence for cleaning frequency.
Oral Health
Whether you're considering cosmetic dentistry, need answers to a dental problem, or just want to improve your daily dental care, you'll find the information you need to keep your smile in top shape.www.webmd.com
In general toothpastes are there for Crest and Colgate to make money, and that fleeting clean minty feeling. Lots of things work better, including brushing, flossing and eating aged cheese after a meal. I still use toothpaste all the time, but I try to buy my fav brand when it is on sale.
Gum disease, gingivitis and periodontitis are a little different, but essentially the once daily routine will do the trick here as well.
Oral-B, Sonicare and manual brushes are all good, but the powered brushes with soft bristles get you there faster and possibly with less harm. And that is the thing....you want to do good and cause as little harm as possible. There is such a thing as too much brushing.
Flossing gets spots a water flosser does not, and vice versa. A water flosser might be better for those that exhibit gingival recession and open contacts and embrasure spaces.
Of course, your mileage might vary. There are people more or less susceptible to disease, but the above is a starting point from which adjustments can be made.
As well, always have a companion that is willing to tell you if you have chicken or broccoli in your teeth. And, better to rinse that out with water, either at the table discretely or in a washroom. Toothpicks in general cause more harm than they are worth and only look good in a dive bar or pool hall.
