- Thread Starter
- #221
You can't guess what this is if you have not heard the artifact. That aside, did you say to put my hand on the tweeter? You should never put your hand on the tweeter much less pushing it in different directions. That is a recipe for damaging it. In this case it is an impossible exercise anyway because there is a rigid metal grill on top of it.My guess is really the midrange is rubbing on the tweeter since there's very little tolerance and a bump in shipping could dislodge it just enough. Try playing a test tone at the resonant frequency and then put your hand on the tweeter and gently push it in different directions to see if that's really what it is.
If you want to help figure out what this is, do as I explained with turning up the volume. Speculating without basis and making excuses regarding shipping and such is not helpful. Playing at low volume and make a recording with a mic at a few inches has nothing to do with the scenario I have explained that causes this artifact. Sit back in a far-field listening position. Keep playing that segment of the song and notch up the volume step by step. Do not stop unless the woofer bottoms out or something (which it never did for me).
You are also welcome to send me your sample and I can test if you can't. Do you own it or did Elac loan it to you?
