nickmas0n29
Hello friends,
What do you think of the Elac ARB51-GE Navis for home listening? Is it worth that money?
I have been searching for 3-way powered speakers with high watt, with detailed imaging and soundstage and can be used without a subwoofer.
I expect to hear a similar sound to my Sennheiser HD 800S headphones coming from the speakers.
I will use my FIIO M17 digital out to Gustard x16 with XLR out.
I also have Denafrips Ares II in hand and RME ADI 2 is in use in the living room.
Will KRK Rokit 103 G4 with class D or G3 with class AB amps do the job? If yeas, which model?
Kali IN 8 3 way, Neumann, Presonus, Yamaha or any other suggestion?
Focal Trio is out of my budget.
Is ribbon tweeter going to make difference as far as the no-fatigue listening for long hours?
The more I search, the more I get confused.
I need help.
Thank you.
I need help.
Thank you.
