Elac Elegant BS 312.2
Hello. I currently own Genelec G4, G3, and 8340 speakers, along with a GLM kit. I also use a pair of IK Multimedia iLoud Precision 6 monitors with my computer. I was able to purchase these at favorable prices because the country I live in has low customs duties on goods imported from the European Union.
With the November sales, I have the opportunity to pick up a pair of Elac Elegant BS 312.2 speakers for 1,000 euros.
I’m interested in trying something different—specifically to experience the sound character of this type of tweeter, as I haven’t heard one like it before.
I have a question, and I would be very grateful for your input: Given the gear I already own, if I were to buy the ELACs, would I find myself saying, "Wow, these are incredible—I’m so glad I spent the 1,000 euros"?
I’m over 40 and primarily listen to rock and metal. I can’t hear frequencies above 15 kHz, and I generally use a bit of equalization for the range above 10 kHz. Because of this, I suspect I might enjoy this particular type of tweeter. Thanks in advance for your responses!
The AMT tweeter is one of the best in it's kind (OEM build by Mundorf i believe), but a 4.5" woofer will never give real bass, or high volume. You surely will need a sub with it and it won't go loud without heavy distortion of that little woofer. As pc speaker (so very close sitting) and with a sub it may be good. But i never heared that model outside a noisy shop, nor saw measurements, so i can't tell if it really delivers. The impression in the shop was that it had no major faults and on low volume sounded quiet decent at least (as far as you can hear that in that noisy envirroment).
AMT tweeter, türünün en iyilerinden biri (sanırım Mundorf tarafından OEM üretimi), ancak 4,5 inçlik bir woofer asla gerçek bas veya yüksek ses seviyesi veremez. Kesinlikle bir subwoofer'a ihtiyacınız olacak ve o küçük woofer'ın ciddi bozulması olmadan yüksek ses seviyesine ulaşamayacaksınız. Bilgisayar hoparlörü olarak (yani çok yakın oturarak) ve bir subwoofer ile iyi olabilir. Ancak bu modeli gürültülü bir mağaza dışında hiç dinlemedim veya ölçümlerini görmedim, bu yüzden gerçekten işe yarayıp yaramadığını söyleyemem. Mağazada edindiğim izlenim, büyük bir kusuru olmadığı ve düşük ses seviyesinde en azından oldukça iyi ses verdiği yönündeydi (o gürültülü ortamda duyulabildiği kadarıyla).
I have a subwoofer; I won’t be sending anything below 80Hz to the ELACs.
I rarely turn the volume up beyond a moderate level. Will I be able to hear details that I didn’t notice with the Genelecs? Is this tweeter capable of providing high resolution without sounding bright?
I haven't heard this model but several AMTs in Adam Audio active monitors. For my aging ears they did sound somewhat revealing, but also bright and quite fatiguing after a short time. My wife who has much better ears disliked them from the start for their "piercing highs" (as she pronounced it). She bought JBLs.
I had also a similar experience with an older ELAC floorstander (first generation FS 247), it seems it though it was a result of its wide radiation without a waveguide, but back then ELAC also included an optional foam ring to place around it and with it I found it fine.
I own Elacs 407.2 with Jet 6 AMT for over a month now and for me the it's actually smooth and not fatiguing. I listen at 85-95 dBA for hours.
I changed from a speakers with Seas Elipsar silk dome tweeter and I prefer the JET6 way more in terms of harshness.
Elacs 407.2'yi Jet 6 AMT ile birlikte bir aydan fazla süredir kullanıyorum ve benim için gerçekten pürüzsüz ve yorucu değil. Saatlerce 85-95 dBA ses seviyesinde dinliyorum.
Seas Elipsar ipek kubbeli tiz hoparlörlü bir hoparlörden geçiş yaptım ve JET6'yı sertlik açısından çok daha fazla beğeniyorum.
Given the equipment I already have, is it worth 1000 euros? I’m not interested in playing at high volumes, and I do have a subwoofer.
No idea, I just gave my opinion on the tweeter (which I like), but I have floorstanders, and this is small bookshelf. Ultimately it's up to you.
The speaker has arrived, and I’ve been listening to it for three or four hours. It didn’t exactly provide a "wow" factor, but it produces a very realistic sound, especially with string instruments. There is no bass; a subwoofer is essential for an enjoyable listening experience. I’ve decided never to buy a speaker that has a ton of reviews on YouTube again. The only speakers I’ll be buying from now on are from the GENELEC ONES series.
