Robbo99999
I think that's a good way to quantify it, and thereby indicate tracks that can stress the tweeter. I'm not sure those same tracks would be the ones that would show the error in the speaker Amir reviewed though. That's why I tested the song that Amir used on my own speakers out of curiosity. I might try it on the track you suggest, but it would be Youtube if it's there.Is this hard to play:
I will use the track Michael Ruff - Speaking in Melodies - Wishing Well (well-recorded fusion) as an example, as there are several high-frequency peaks that require a lot of power from the amplifier. First, the voltage, current and power for the entire signal are shown:
View attachment 474794View attachment 474795
Hi there!
I'm creating this little thread to ask a question for what is probably a very dumb question, but I can't for the life of me figure it out.
Let's say you have speakers rated for 88 dB sensitivity (2.83 V @ 1m).
The speakers' maximum SPL is 112 dB.
Their power rating is 40 to 120 W.
Now, adding 3 dB means doubling the volume. Going (112 - 88) / 3 = 8, so going from 88 dB to 112 dB is multiplying the volume by 2^8, which is 256. Am I correct on that one?
If that's true, then I don't get the numbers in the spec sheet. 1W gives you 88 dB, so to get 112 dB you should need 256W...
- JustAnAudioLover
- Forum: General Audio Discussions
If that song requires a lot of amp power even for the higher frequencies, it also places demands on the speakers.
