ELAC DF63 Floor standing Speaker Review
Rate this speaker:
    Votes: 85 39.4%
    Votes: 109 50.5%
    Votes: 18 8.3%
    Votes: 4 1.9%
This is a review, listening tests, and detailed measurements of the ELAC DF63 Debut 3.0 Tower speaker. It was kindly drop shipped and donated by a member. It costs US $649 each.
The DF63 looks no worse or better than I expected which means, it is fine. :) Nothing exciting in the back other than the two ports:
I appreciated close to the ground terminals as there is less chance of speaker wire resonating against the cabinet. And rear ports means that their high frequency distortion is less likely to be audible.
As usual, if you are not familiar with my speaker measurements, please watch this video first:
ELAC DF63 Speaker Measurement
As usual, we start with our family of anechoic frequency response graphs generated by Klippel Near-field Scanner:
ELAC Debut 3.0 DF63 Tower Floor Standing Speaker anechoic CEA CTA 2034 frequency response meas...png
If you stand back (or filter the graph), the on-axis response generally looks level. Closer examination shows something untoward happening around 900 to 1000 Hz. And a few resonances at 90 and 180 Hz. Treble response also has some variability. But again, at high level, this is not bad.
Sensitivity is specified at 87.5 dB and it gets there, making it about 1 to 2 dB better than average (can get louder with the same amplification power). This is a common benefit of tower speakers with multiple woofers.
Directivity is reasonably smooth although doesn't follow a monotonic trend. This messes (badly) with early window reflections:
ELAC Debut 3.0 DF63 Tower Floor Standing Speaker anechoic CEA CTA 2034 early window reflection...png
And as a result, in predicted in-room frequency response:
ELAC Debut 3.0 DF63 Tower Floor Standing Speaker estimated in-room CEA CTA 2034 frequency resp...png
Showing just one port and woofer, we see the reason for some of the anechoic frequency response errors:
ELAC Debut 3.0 DF63 Tower Floor Standing Speaker driver and port frequency response measurement.png
While this is a 3-way rather than (messy) 2.5 way speaker, it still suffers from multi-sourced interference including a port/cabinet resonance.
Back to directivity, we see very well controlled one horizontally above 1 kHz:
ELAC Debut 3.0 DF63 Tower Floor Standing Speaker horizontal beam width measurement.png
ELAC Debut 3.0 DF63 Tower Floor Standing Speaker horizontal directivity measurement.png
Vertical is messy despite the midrange:
ELAC Debut 3.0 DF63 Tower Floor Standing Speaker vertical directivity measurement.png
See the messiness around 1 kHz in both graphs.
Distortion test generated very surprising results:
ELAC Debut 3.0 DF63 Tower Floor Standing Speaker relative THD distortion measurement.png
ELAC Debut 3.0 DF63 Tower Floor Standing Speaker THD distortion measurement.png
I have not ever seen such a massive jump in distortion with 10 dB in this class speaker! We go from better than average to worse than average. Here is a comparison with 5 dB increments:
ELAC Debut 3.0 DF63 Tower Floor Standing Speaker relative THD distortion vs level measurement.png
I could hear some audible distortion at 96 dBSPL which got highly exaggerated at 101 dBSPL, rattling the entire structure of the Klippel NFS. In other words, what there is, is amplified by the cabinet.
Impedance is on the low side:
ELAC Debut 3.0 DF63 Tower Floor Standing Speaker impedance and phase measurement.png
Waterfall and step responses are as expected:
ELAC Debut 3.0 DF63 Tower Floor Standing Speaker CSD Waterfall Response measurement.png
ELAC Debut 3.0 DF63 Tower Floor Standing Speaker Step Response measurement.png
ELAC DF63 Speaker Listening Test
Listening tests were made in our massive (volume wise) living room as you kind of see in the review picture. Immediate impression was that of (pleasant) warmth and full range response I don't expect to hear in this class of speaker. Fidelity was good enough that I started to question what I had measured. So I jumped right into my sub-bass test tracks to chase down the distortion there:
Sub-bass was reproduced better than this speaker has any business delivering! I almost stopped there but glad that I did not. At 30 seconds, there are some high frequency (strings?) that normally don't bother any speaker I have tested. Oh boy. Did it upset the DF-63. Massive, and I mean massive resonance set into tweeter, creating screeching sound that was nearly as loud as the notes themselves! I reduced the volume down to some -10 dB but I could still hear it. My wife was next to me so I asked her if she could hear it at around -5 dB and she could! :) This is a flat out failure in my book and reminds of another ELAC speaker with the same problem although here, it is far worse.
I tried to detect the problem in other clips and it was much harder. I could hear strangeness in high notes in other tracks but wouldn't bet my salary on it and nowhere as clear as the above track. I can't imaging it not being there in other clips though.
As an aside, above is a great example of using carefully selected audio tracks for speaker testing, than whatever you normally listen to.
On bass, the deep notes were very satisfying. As I cranked up the volume, I could tell they would start to get distorted and muddy but this was at rather elevated levels.
On EQ, I filled in the 1 kHz hole and it opened the sound fair bit, making the stock sound wooly and too warm and closed without it.
The DF63 seems to have a different recipe than many other speakers I have tested. It seems to aim for deeper bass at the expense of higher distortion/lower SPL playback. There is also some interference around 1 kHz which EQ seems to paper over. The main issue as you can imagine, is that tweeter. I don't mind gradual distortion or power limited but not this kind of massive and sudden break up. Yes, I was listening kind of loud. :) But once I got sensitized to it, even playback at moderate levels was audible.
On the positive front, the deep bass is extremely satisfying, making the speaker nearly full range which is remarkable in this price class. Sensitivity is higher than normal, meaning less demand on the amplifier.
I am sad to give a failing grade to ELAC DF63. Some technical flaws I can't get over and such is the case with tweeter response here.
Thank you Amir. Just a question, the tweeter distortion ≈30s was that from the Terje Isungset track?
Thanks. Don't know if you have the speakers up still, but distortion also audible on the song "bass drop" by Nenad Vasilic?
I was hoping the new tweeter can fix the narrow dispersion of Debut 2. But now I may actually feel lucky getting my B6.2 just a year before 3 came out.
Thank you very much for this review!
The song you used is very nice, and as the bass and treble parts are well separated, it is definitely excellent for speaker testing.
At 30s I hear percussions rather than strings though!
It is indeed a good test track for loudspeakers and headphones. This speaker seems to suffer from avalanche distortion in the bass. So I wonder how Nenad Vasilic ”bass drops” sounds on them. Also a track that can be cranked up quite high SPL.
Pity for the flaws, else it would be an awesome speaker. Thanks again for all your work Amir.
I tore everything down already. I do have that song as one of my test clips but it is way down in the playlist.
Looks like something happening during shipping or just poor quality control. Erin also got in this model and it doesn’t show the issue at 1kHz nor does it show the terrible tweeter distortion at 96dB.
I looked at his frequency response measurements. His is always smoother than mine which would hide some of that dip.
In my last issue with ELAC, similar hypothesis was made that mine was unique but then another reviewer heard it too. I felt the tweeter and it is solidly mounted in there.
Why are people reserving thread slots?
Here is my take on the EQ.
Please report your findings, positive or negative!
For the score rational your journey starts here
Explanation for the sub score
The following EQs are “anechoic” EQs to get the speaker right before room integration.
If you able to implement these EQs you must add EQ at LF for room integration, that is usually not optional… see hints there.
The raw data with corrected ER and PIR:
Score no EQ: 5.9
With Sub: 7.2
Spinorama with no EQ:
Directivity:
Better stay at tweeter height
Horizontally, better toe-in the speakers by 10/15deg and have the axis crossing in front of the listening location, might help dosing the upper range. explanation here
EQ design:
I have generated two EQs. The APO config files are attached.
  • The first one, labelled, LW is targeted at making the LW flat
  • The second, labelled Score, starts with the first one and adds the score as an optimization variable.
  • The EQs are designed in the context of regular stereo use i.e. domestic environment, no warranty is provided for a near field use in a studio environment although the LW might be better suited for this purpose.
Score EQ LW: 6.0
with sub: 7.6
Score EQ Score: 6.7
with sub: 8.2
Code:
ELAC DF63 APO LW EQ 96000Hz
September052025-211222
Preamp: -3.00 dB
Filter 1: ON HPQ Fc 41.5 Hz Gain 0.00 dB Q 1.35
Filter 2: ON PK Fc 111.2 Hz Gain -2.88 dB Q 1.67
Filter 3: ON PK Fc 462.6 Hz Gain -1.42 dB Q 1.91
Filter 4: ON PK Fc 1375.5 Hz Gain 1.85 dB Q 5.08
Filter 5: ON PK Fc 1003.7 Hz Gain 2.72 dB Q 3.31
Filter 6: ON PK Fc 3974.2 Hz Gain -1.29 dB Q 5.32
Filter 7: ON PK Fc 8549.9 Hz Gain 3.58 dB Q 0.69
Filter 8: ON PK Fc 9374.2 Hz Gain -3.02 dB Q 1.93
ELAC DF63 APO Score EQ 96000Hz
Preamp: -3.00 dB
Filter 1: ON HPQ Fc 41.5 Hz Gain 0.00 dB Q 1.36
Filter 2: ON PK Fc 112.1 Hz Gain -3.11 dB Q 1.48
Filter 3: ON PK Fc 448.4 Hz Gain -1.48 dB Q 1.61
Filter 4: ON PK Fc 1366.8 Hz Gain 1.88 dB Q 4.02
Filter 5: ON PK Fc 971.4 Hz Gain 2.98 dB Q 4.66
Filter 6: ON PK Fc 3951.5 Hz Gain -1.30 dB Q 6.00
Filter 7: ON PK Fc 8455.3 Hz Gain 2.70 dB Q 1.28
Filter 8: ON PK Fc 9389.6 Hz Gain -3.35 dB Q 1.90
Spinorama EQ LW
Spinorama EQ Score
Zoom PIR-LW-ON
Regression - Tonal
Radar no EQ vs EQ score
No improvements?
The rest of the plots is attached.
  • ELAC DF63 APO LW EQ 96000Hz.txt
  • ELAC DF63 APO Score EQ 96000Hz.txt
They will be computing preference scores and such and posting it later. It is nice to have them early in the review thread and hence the reservation.
