liquidman101
- Joined
- Apr 7, 2021
- Messages
- 37
- Likes
- 41
Yeah, a DAC with volume control and XLR outputs and you're set. Topping D30 Pro, SMSL SU-9 or Gustard X16 for example. No need for a separate pre-amp unless you have analog sources or want a headphone amp.
Thanks for that Eetu - I prob will get a pre-amp as I might get myself a turntable at some point. Do you have any thoughts on CD players in the affordable range? Or are they all pretty much the same? Cheers for your advice.
