Roland68
Out of your list, I believe the R3 Meta is the best.
Note that speaking in percentages is very subjective and subject to error. But my experience trialing the ELAC DFR52 vs the Buchardt S400–another top speaker in that price range–tells me that moving to speakers in the $2k/pair range would get you a solid 35% improvement in sound quality.
The S400 MKII is another speaker I'd look into. Great measurements. I'd prefer it over the R3M due to a little wider directivity and better bass.
In a direct comparison, the DFR52s are significantly inferior to the DBR62s. I actually wonder how ELAC’s development team failed to notice this. Aside from the tweeter and the manufacturer, the two speakers don't have much in common.First of all, thank you so much for the excellent expert recommendations.
I wasn't familiar with the Elac Debut Reference DFR52; it costs around €700 per pair here in Europe. However, it's not suitable for my room, or more precisely, my 14 m² room (at least I don't think so). I believe the DBR-62 would be better suited for a smaller room? I'm considering replacing it with the DFR52, then I wouldn't need the Elac RS500 subwoofer anymore. But I think that would be pointless.
The Buchardt S400 MKII costs €2800 here, which is too expensive for me. I'd like to stick with the KEF R3 Meta, which costs around €2000 per pair. But that's just a plan, and I'll probably stick with the R3 Meta. Does this mean that the R3 Meta is a good alternative to the DBR62 in the €2000 range and I don't need to speculate about other alternatives?
It also doesn't surprise me that the difference compared to the Buchardt S400 is so pronounced. The gap between them and the DBR62s would likely be much smaller.
See also post #3086.
If you’d prefer to do without a subwoofer and opt for floor-standing speakers instead, I can recommend the Heco Aurora 700 or 700XT.
