The R3 Meta costs €2000 per pair, four times as much as the DBR62. And perhaps there's no audible difference at all? Is the Elac DBR62 really that good? I can't compare it to any other speakers; I only had the Teufel Ultima 40 with a cheap Denon AV receiver, whose powerful (but boomy) sound I enjoyed for years. And of course, the sound was significantly more pleasant after switching to the DBR62. As for subwoofers, I've tested several and can say that the sealed Elac RS 500 subwoofer is very good. A sealed enclosure is significantly more precise.
I've always assumed that something that costs considerably more must also be better.
Why shouldn't I replace my Yamaha RN800A with something better, like the Cambridge EXA100? Assuming I buy an R3 Meta, wouldn't a better amplifier then also justify a KEF?
Or does room acoustics actually play a much bigger role? Should I get an amplifier with room acoustics analysis, or is the upgrade not worth it?
I performed the measurements myself on my Yamaha YPAO, but honestly, I didn't want to get used to it (even though it produces a slightly different sound, more treble and midrange, but less bass). It might be better, but I figured if I replaced it with the Cambridge EXA100, I wouldn't need the room acoustics analysis anyway. A somewhat naive thought, but that's how I came up with it.
I also have a 30-square-meter room where I watch TV. Would it be better to set up my Elac DBR62 speakers and the RS500 subwoofer there? Would upgrading to better speakers and an amplifier without room acoustics analysis make sense?
Or would it be better to stick with the Yamaha RN800A and use its room measurement function instead of using a more powerful, better amplifier without room acoustics analysis?
