ZolaIII
- Joined
- Jul 28, 2019
- Messages
- 5,708
- Likes
- 3,417
@pathtonowhere do to phase rise angle let amplifier breed. They aren't exactly very inefficient either with little over 85 dB (1W 8 Ohms to 1m). That Yamaha will give you good 70W, 130W sustained (and on a long run) which is 103, 106 dB (to base of 85) - 6 dB (actually less in the room but not much) for every doubling of distance (93~96 to far range 4 m). So you ain't gonna even use that much and apm will be fine. Let's say woffer (alu coted more linear but higher mass and don't worry dosent ring) won't be remotely happy with more than 100 dB, it will compress. It can probably push out more properly stressed out and if you cut it high enough (120 Hz) you don't have the problem in the first place. Their cabinets really ain't prized enough.
Invest some money in deacent measurement microphone if you didn't done that all ready and see what you need to improve.
