silent-amp
- Joined
- Aug 7, 2025
- Messages
- 48
- Likes
- 23
Elac Debut Reference DBR-62 and Mission 778x amp would be a good match?
are you sure about having the *same* xover?... that seems pretty difficult to do...with same XO and tweeters.
Go to data and take a look at impedance/phase plot (do the same on Stereophile B6 page).are you sure about having the *same* xover?... that seems pretty difficult to do...
thanks , I'm learning....Go to data and take a look at impedance/phase plot (do the same on Stereophile B6 page).
From my understanding the Sb41Go to data and take a look at impedance/phase plot (do the same on Stereophile B6 page).
We're the the SB41 and the B6 both designed by AJ? I am not sure about that. It appears the B6 was but the Sb41?Go to data and take a look at impedance/phase plot (do the same on Stereophile B6 page).
Best would be to ask him, tho he doesn't come often nor works for Elac anymore.We're the the SB41 and the B6 both designed by AJ? I am not sure about that. It appears the B6 was but the Sb41?
What do you mean by that?as Sonos Amp's line in is not that great.
It is not clear as digital input, I don't know if it is noise or any other factor. Also sound is weak when compared to airplay the same source.What do you mean by that?
Probably just a difference in level.It is not clear as digital input, I don't know if it is noise or any other factor. Also sound is weak when compared to airplay the same source.
I tried all option in sonos input level but still mediocreProbably just a difference in level.
No frequency response measurements exist of the Nota 260 X, its performance is therefore unknown.Im thinking about swapping indiana line 260x for something better. Are DBR-62 on higher lvl in sound quality terms than 260x or switching these two monitors doesnt make sense?
If the specs are accurate, then yesDo you think the amplifier module "Hypex Ncore NC122MP" is good for the DBR62?
AUDIOPHONICS AP300-S125NC Power Amplifier Ncore NC122MP
The Audiophonics AP300-S125NC is a stereo amplifier based on a Hypex Ncore NC122MP amplifier module. It is ideal for providing a significant power reserve (2x125W @ 4Ω) without sacrificing sound reproduction quality.www.audiophonics.fr
