silent-amp
- Joined
- Aug 7, 2025
- Messages
- 48
- Likes
- 23
Je n'aime pas le chêne et le noyer![]()
So version with black cabinet finish does exist!Elac Debut Reference B6.2 -Stückpreis Regallautsprecher - Hidden Audio
| Elac Debut Reference B6.2 -Stückpreis Regallautsprecherhidden-audio.de
good to know!Elac Debut Reference B6.2 -Stückpreis Regallautsprecher - Hidden Audio
Yea, they should add it to the site for those who prefer all-black version.In the offical ELAC site is not displayed:
Welcome to ASR,I'll buy my first system in the near future and based on the reviews decided to go with these speakers. I'm having some doubts about wich amp to pair with them, but have been eyeing a yamaha S-301 for 200€ (I'm in europe). Would that be a good amp for these speakers? Or should I look somewhere else?
I don't have a turntable and I don't need sub so SMSL AL200 looks very interesting to me. I wish it had more digital inputs though..I will be connecting a turntable to the amp and speakers, the SMSL AL200 would require an external phono preamp, a scenario that I want to avoid for now, otherwise the AL200 seemed amazing, thank you very much for your reply, silent-amp.
By huge I mean a 'cathedral-sized' listening space. The combination of the Yamaha 301 and ELAC DBR62 will work in your space.I will be connecting a turntable to the amp and speakers, the SMSL AL200 would require an external phono preamp, a scenario that I want to avoid for now, otherwise the AL200 seemed amazing, thank you very much for your reply, silent-amp.
What room size would you consider adequate for the Yamaha S-301, Power Pop 23? I will be placing the setup in an open-space ( living room + kitchen). It is not big, but the layout is weird and there is a small wall behind the couch dividing it from half the kitchen.
Speaking of an all black finish, has anyone ever compared this speaker (DBR62) to the original Elac Debut B6 that had the black finish as the only choice? If I remember correctly the Debut B6 measured well according to online reviews. IIRC the Debut B6 has a big cabinet and sounded quite nice but there were resonances in the cabinet and the speaker exhibited rolled off highs past 10kHz. Regardless I just remember enjoying the sound quite a bit and curious about the difference in sound signature between the original B6 and the DBR62.So version with black cabinet finish does exist!
Here image from that site:
I mean the original B6 not the B6.2 . I really enjoy the original B6 and wanted to know if anyone has compared to the b6.2 and the DBR62This is a review and detailed measurements of the ELAC Debut 2.0 B6.2 bookshelf speaker. It was kindly purchased by a member new and sent to me for testing. It costs US $245 from Amazon including free shipping.
The Debut 2.0 has a decent look:
It comes with an external grill that I did not use. But I did leave the tweeter screen in place for testing. It is likely a nod to retailers putting these in showrooms trying to keep fingers away from the delicate tweeter.
The finish is fine except I saw a fine white line above the speaker:
Back panel is as you expect...
- amirm
- Forum: Speaker Reviews, Measurements and Discussion
Have you actually tried the B6 and DBR62? It would be interesting. I do like the b6.@!$ I am interested in trying the dbr62. The measurements on the B6 were decent IIRC but the highs appear to be more rolled off than the dbr62Lot of misses with those and surprisingly good outcome even so. Still wouldn't really compare them with DBR62's.Elac Debut B6 loudspeaker Measurements | Stereophile.com
Sidebar 3: Measurements I used DRA Labs' MLSSA system and a calibrated DPA 4006 microphone to measure the Elac Debut B6's frequency response in the farfield; for the nearfield frequency response, I used an Earthworks QTC-40, which has a ¼" capsule and thus doesn't present a significant obstacle...www.stereophile.com
No I didn't.Have you actually tried the B6 and DBR62? It would be interesting. I do like the b6.@!$ I am interested in trying the dbr62. The measurements on the B6 were decent IIRC but the highs appear to be more rolled off than the dbr62
Thanks very much! That is a great link!No I didn't.
Take Stereophile measurements with grain of salt. So let's compare Elac SB41 instead taking it as smaller brother of B6 with same XO and tweeters.
Let's keep in mind cabinet resonance would be less pronounced with smaller woofer of BS41. The advantage of DBR62 is very sturdy cabinet and front port. So very little resonance from cabinet and easyer to place and it really shows in treble from 4.5 to 8 KHz where DBR62 does much better but it's not something which can't be corrected with wide PEQ. However 14 to 18 KHz deep can't but I don't see that as critical area. For more advice is go and listen to DBR62's when you get chance.Easily compare loudspeakers measurements
www.spinorama.org
