GelbeMusik
- Joined
- Apr 19, 2020
- Messages
- 445
- Likes
- 290
The harmonic order is actually labeled in the graph (click on it for larger image):
The 270 Hz one is almost entirely 2nd harmonic. The next one though 2.7 kHz) is 2nd and 3rd order.
There is so much info here, I overlooked the details. Nevertheless, the ELAC is a quite special design. Again, if it was mine I would have dumped it, taking care that nobody ever would take note. Maybe I'm a bit shy, though.
The story I could tell about locally accummulating distortion is told in post #50. The system simply gets out of hand. From an engineering perspective that should be considered a limitation, a "never exceed" warning is in order.
For the time being I'm happy to have repaired the said 12NDA520 from 18sound, that in contrast to its 0,05% distortion in the midrange (@some 100dB) had this miniscule issue with a rattling glue point. Actually it was detected with recreational listening first. Only after I've seen it in the measurements, using adopted tech to find it. My hypothesis is, that a technically experienced listener would detect mechanical issues with a driver easily. Because there is a specific signature to it.
On the other hand, ELAC addresses the Slims to an audience, which isn't really that fond of high fidelity. Of course they want to buy the best for general economic reasons. But once done, these people settle easily to what they have, not questioning its merits or flaws further. And listening volume, lets say, 75dB is way enough. Even that would make it hard to speak to each other ( measured and blind tested sighted ).
But one caveat: these are no way capable of giving the sensation of standing right besides a Bechstein grand piano. Some others can.
