I'm actually surprised it didn't rate a bit higher. There are dips in the FR but they are quite narrow-band, while the overall balance is actually pretty neutral. And the off-axis behaviour is quite well-controlled.
Not a criticism, obviously, and not arguing with the maths lol. Just a little surprised it was apparently penalised so heavily for these particular shortcomings.
EDIT: I also would have thought little weight would be given to the top-octave off-axis droop, as this region of the audio spectrum is perceptually not very important. Or are all spectra weighted equally in the calculation? I'll have to read up on it, has been a while...
It is rare for me to contact manufacturers let alone wait on them.You didn’t wait very long for Andrew’s response. I would imagine you had less of a deadline than he may have had.
If you look at the score breakdown, it was the smooothness of the predicted in room response that really hurt it. This is the part of the score I always have the most trouble "eyeballing." That and the narrow band deviation on axis. MZKM calculates a score using the listening window too, but the ELAC doesn't improve that much because the response doesn't really smooth out until quite a bit off axis (compared to, say, the Kali In-8, which improves very much with off axis listening)
As for weighting of the droop, the Narrow band deviation scores cover the regions from 100 to 12000Hz, while smoothness one covers 100 to 16000. That said it's been said before that a potential flaw with the formula is that it weighs every part of the frequency response equally. A narrow-band error at 11KHz or beneath schroeder is sure to be less of a problem than something in the sensitive upper mids and presence regions.
That 200Hz dip will be very audible, and it indeed heavily impacts the score.I'm actually surprised it didn't rate a bit higher. There are dips in the FR but they are quite narrow-band, while the overall balance is actually pretty neutral. And the off-axis behaviour is quite well-controlled.
Click my signature (doesn't appear on mobile if in portrait mode).My apologies for the dumb question, but where is the score breakdown? I only saw the two numbers for SCORE and SCORE ignore LFX in @MZKM's post.
SoundStage has measured some; some good, some not (I believe the XT models noticeably did better than the non-XT ones).Amir, thank you for your hard work and measurements, I hope to see some Martin Logan’s Motion bookshelf’s one day.
Please Review Triangle I am about to buy Titus ez or comet series.. also please review Buchardt s400 and kef r3'splease don’t review Triangle speakers..please![]()
1: NoSo the main questions I guess I'd like to find answers for are:
- Are peaks in FR penalised more heavily than dips (as they should be)?
- Is the frequency-dependent sensitivity of the human ear taken into account when weighting a speaker's performance in the various frequency bands? (If I understood you correctly, the answer is no.)
- How specifically does the metric deal with lobing? It seems the penalty is very low.
The S400 is supposed to be coming.also please review Buchardt s400
At least you then will have another speaker with manufacturer measurements to compare. This ELAC didn’t even state a +/-dB for the stated frequency response (and I see why, I calculated +/-4.7dB; and if wondering why they chose 41Hz and not 40Hz if not stating +/-dB, I got 41Hz for the -6dB point).The S400 is supposed to be coming.
1: No
2: Correct (no)
3: Vertical performance is a part of the predicted in-room curve.
However, ceiling and floor reflections are not overly audible.
In the far-field, the listening window for vertical performance is less that +/-5°, so it’s not that important. For near-field it is, but that’s not what this formula is based on.
YOu mean this region?And finally, one (I think) last question about the ELAC: The Spinorama shows a rather large dip in the Sound Power, Early Reflections, and Predicted In-Room Response between 1kHz and 2kHz. These dips are significantly larger than the small dip in the same frequency range in the on-axis response, yet there is no peak in this range in the Sound Power DI or Early Reflections DI. This seems odd to me - are you aware of how this could be?
