I have been wondering about the following:
If we assume a system with a perfectly flat magnitude response after correction based on in room measurements - will the distortions still show the distortion caused by room modes (standing wave causing peak/dip) that were previously corrected and is there a way to reduce them? (I've got the idea after reading about some people saying that they could localize subwoofers with a 80Hz crossover or lower)
As an example this is the response in my room with dual SVS SB-2000 (blue: time aligned and with a -5dB LS at 14Hz to reduce the room gain; orange: PEQed response):
(measurement done with a UMIK-I so the response below 10Hz isn't as accurate)
Would the Distortion with Harmonics at ~32Hz and ~65Hz be amplified by ~10dB?
A direct reduction would only be possible by using a lower distortion driver or reducing the level of the fundamental.
Are there any ways this could be corrected other then active or passive room treatment? If so, has there been research on active distortion reduction at the listening position using destructive interference? (if not, would I consider it as a topic for my master thesis in a few years)
