Building a 2.1 setup for a small room — prioritizing sound quality, soundstage, and precise bass over raw output. Want to expand the low-end and having trouble deciding on a sub.
Current mains: Edifier R2750DB MKII ( 3-way active 7″ woofer, 4.5″ mid-range, 1″ silk dome tweeter , ~45Hz rated, has SUB OUT).
Choosing between two ~$200 subs:
Questions:
Appreciate any measured data or firsthand experience.
- Edifier T5S: 8" driver, 70W, 35–115Hz, ~150mV input sensitivity, adjustable low-pass, phase switch, RCA only.
- PreSonus Eris Sub 8BT: 8" driver, 50W, 30–200Hz, variable gain (-30/+6dB), variable low-pass (50–130Hz), defeatable 80Hz high-pass on pass-through, polarity switch, TRS+RCA.
Questions:
- Is R2750DB MKII + T5S (same-brand pairing) a solid choice? I've seen one review mention it lacking in bass, but that's a single data point — anyone with firsthand experience?
- Does anyone know if the R2750DB MKII's SUB OUT is already crossover-filtered, or full-range?
- Is 150mV input sensitivity (T5S) fine for a typical DAC line-out, or borderline? There's also a question of whether the sub reliably wakes from standby off that signal level.
- Anyone run a PreSonus sub off a non-PreSonus main speaker's sub-out? Curious if the Eris Sub 8BT's pass-through stays live during its 40-min standby, or mutes.
- Any technical reason to expect one sub to have tighter/deeper bass than the other in a sealed nearfield setup, or is it mostly gain-staging/placement?
