Edifier s360db
spiritchaser
Hi,
I have Edifier S360DB speakers. I would like to place the speakers in two corners, but this would require a 10-meter 5-pin DIN cable. This type of cable is not available commercially in 10-meter form so it must be custom-made. However, this would require the pin-out diagram for the cable. Could anyone help me with this? Thank you.
You can make your own Pinout diagram using a basic $10 multimeter.
Set the multimeter to continuity mode (the one that beeps when you touch the two probes together), then take the stock DIN cable and see which input pin beeps with which output pin.
Note down the result and you have the pinout.
Thank you!
