Edifier MR5 Review
Nuyes
Reviewer
South Korea
This is the new MR5 from Edifier, the company behind the well-received MR4. I’m curious to see if it can become a new legend in the budget category.
It uses an active–passive configuration, where one active speaker receives all the input signals and sends them to the passive unit. I give high marks for supporting RCA, TRS, and XLR inputs. There are also shelving filters to adjust bass and treble levels.
What really sets this speaker apart in its price range is its unusual structure. The tweeter–midrange driver is exposed on the front panel, while a 5-inch woofer is hidden inside a side-mounted slot.
It’s impressive that they’ve managed to produce an active 3-way speaker at this price point — around KRW 120,000–130,000 as of August 15, 2025.
Frequency Response
Overall, the balance is quite flat, with bass extension reaching down to about 48.2 Hz (-6 dB). It did not disappoint.
Before moving on, I’d like to briefly revisit my measurement system and methodology.
I use the Merging Nearfield and Farfield Method to measure a loudspeaker’s response.
When the measurement environment and procedure are well-controlled, this approach offers high reliability in the mid- to high-frequency range. However, in the time domain, the lower measurement limit depends on the gap (time difference) between the direct sound and the first reflection when applying window gating. With my 5 ms window, the theoretical lower limit is about 200 Hz, and I typically merge the nearfield and farfield responses two to three octaves above that to be on the safe side.
For this product, however, the woofer-to-midrange crossover point lies below 200 Hz, which meant I couldn’t obtain a fully accurate merged response using my usual method.
Without going into every technical detail, in such cases I take multiple farfield measurements at varying time/position settings, progressively reducing error until I find the most reasonable merge region and matching level. This approach has allowed me to measure other 3-way loudspeakers—such as the KEF Blade Two Meta and Genelec 8331A—without significant issues.
This time, though, was different:
The woofer is hidden inside the cabinet, and its low-frequency output only emerges through side-facing slits.
Naturally, I still aimed to get as close to an accurate response as possible—and to verify that result.
The “secret weapon”: In-Situ Compensation​
This technique uses a reference loudspeaker with a known anechoic response.
While it’s extremely difficult to fully model how a room imposes dips, peaks, and other distortions on a loudspeaker’s output, we can treat it as a function of the relative positions of the room, speaker, and microphone.
The idea is:
  1. Measure the reference speaker in the room.
  2. Divide that measurement by its true anechoic response to isolate the room’s transfer function.
  3. Measure the target speaker in the same position.
  4. Divide that result by the room’s transfer function to (theoretically) recover the target’s anechoic response.
Of course, this is an idealization—this works perfectly only if the reference and target loudspeakers have identical radiation characteristics. In reality, differences in woofer and port size, position, and dispersion patterns will always cause some deviations.
As shown above, I used the anechoic response of my AsciLab C6B sample to derive the room’s transfer function in my measurement space. Placing the MR5 in the same position and applying that correction produced the orange trace above.
The narrow peaks you see are caused by small differences in driver layout, component positions, and directivity, but they’re still sufficient to confirm how closely the merged nearfield + farfield result tracks the In-Situ Compensated curve.
And indeed, the merged response followed the compensated response very well.
Nearfield Measurements
The port response is clean, just as I’d hoped given the large port and generous flaring for its size. That said, the woofer’s operating range is inherently limited by the 3-way crossover, which might be why port noise isn’t obvious.
The mid–tweeter crossover doesn’t overlap, and there’s a noticeable boost in the tweeter response around 4 kHz — possibly intentional, or perhaps to create a broad dip centered around 5–6 kHz.
CEA-2034
Aside from the unusual 4 kHz feature, the smooth tonal balance and DI are quite good. Woofer placement causes some directivity around 100 Hz.
Directivity
In the highest frequencies, dispersion widens, but given the FR and listening window, this seems like an optimal compromise. Despite the shallow waveguide, the relatively high ~3 kHz crossover keeps any mid/tweeter directivity mismatch from becoming pronounced.
A narrower gap between tweeter and midrange might have been preferable with such a high crossover, but there are many design trade-offs to consider.
Line Chart
Most horizontal angles show smooth attenuation — except around 4 kHz, which remains an oddity.
As seen in the contour plot, the crossover region is smoother below the axis than above. This is worth keeping in mind when setting listening height.
Beamwidth
Polar Plot
Apart from the unusually wide 5 kHz band, off-axis decay is smooth.
The seemingly perfect vertical polar is just an illusion — the ~3 kHz crossover point doesn’t appear in my polar plots.
THD
The woofer’s performance in the bass range isn’t outstanding. While 3-way designs have the potential to optimize each driver’s strengths, I don’t see much evidence of that here.
Odd-order distortion is less of a concern, but even-order components in the woofer range are higher than in the MR4’s 4-inch woofer. Since the woofer fires downward, gravity and suspension asymmetry could cause even-order distortion to change over time. Let’s hope the suspension is strong enough to resist mechanical aging.
Multitone Test
Here’s where the 3-way advantage shows. Some users might find this alone convincing.
80Hz~
There’s a noise component around 400–500 Hz at low output, but otherwise it holds up well.
Compression Test
If you don’t expect outstanding dynamics, the results are perfectly acceptable for the price.
Deviation between 2 samples
You can’t expect tight matching of three drivers and crossover parts at this price. The 4 kHz quirk seen earlier may be unique to the sample I measured, pointing to unit variation.
Final thoughts
I was curious about this speaker from the moment it was announced. A 3-way active speaker at this price was enough to catch my attention — especially from Edifier, the maker of the MR4.
Overall, I think it’s an impressive achievement, and simply bringing it to market without glaring faults deserves praise. But the more I examined its performance, the more the price made sense: from driver selection to design choices, it doesn’t feel like a product conceived from the ground up as a 3-way system.
Interesting review, and with an artwork again - this time a meditating alien
Edifier keeps on delivering, $300 for this kind of performance feels like a good deal. It even has Bluetooth!
Yeah, but considering they must already have a DAC in there for the Bluetooth I rather wish they'd add other digital inputs like SPDIF and USB. Lack of such is what ultimately led me to choose another brand for my desktop speakers.
I just got a pair of these delivered today. Just waiting for my partner to wake up so I can try them out.
In the other thread some asked about hiss from the speaker. I have a handheld db meter. Background baseline for my apartment is about 32.2 db. With the speaker max volume there is a very small hiss that is audible to my ear inside of 10 inches. If I put the db meter almost touching the tweeter the reading was 34.4 db. Moving the meter back it returns to 32.2 at about 10 or 11 inches. I have no hearing loss or anything so I think unless you are for some reason only 10 inches away from the speaker it's a non issue.
The acoustic tuning in the app for corner placement etc seems to not be customizable for each speaker. Only both speakers at the same time. I have one in the corner that I eq with Peter's apo to bring down the bass on my MR4's so was hoping it was speaker independent. Not too big of a deal.
Also the version in Canada doesn't come with foam angled risers. I didn't need them but something to note.
Replacing MR4's with these. Very excited!
Thanks for doing the work and measuring them.
Great to have another source of reviews here, thank you very much. I enjoyed your explanations too.
Looks like a great value speaker, nice.
What's also encouraging is that this is a mainstream brand. People will buy them without knowing anything about the measurements, and get good sound. Might set some new people on the hifi journey!
Great review, Fine to listen off axis w/o EQ functions, weird 800hz compression problem, Lotta features.
The other competitor in this space is the Adam D3V which is a lot smaller but better overall response and directivity but due to small woofer also has a lot higher distortion, both seem really solid though. I haven't seen a ton of Edifiers that I really like but this looks solid. Overall good value.
I'm also waiting to see people review the Kanto Ora and Ora 4 with measurements in the same price range.
@Nuyes
The fact that the 1m non-anechoic measurements shows dulating frequency response means that the harmonic distortion measurements in the bass are very inaccurate.
To put it another way, if bass FR is measured only accurately in the nearfield, then surely harmonic distortion of bass frequencies is only accurate as measured in the nearfield (or on outdoor ground plane)?
Will you consider measuring bass distortion more accurately? Also, what about Time Domain?
The concept of a down-firing woofer crossed at 150Hz, and rear/rear firing port makes sense from a directivity point of view, since wavelengths of these frequencies are virtually omnidirectional. On the other hand, LR4 filters this low increases the normal group delay. Except that in this case they were constrained on using a 5" midwoofer as a subwoofer below 150Hz and 3.5" midwoofer as the main drive unit.
I feel the concept, as a 3-way with a down-firing woofer would have been better executed with a larger woofer. (But then, which 3-way speaker isn't?)
But of course, the cabinet would need to be a lot larger that what Edifier's use case would be. It's a tricky set of compromises.
So more importantly, how does it sound to you, compared to the MR4?
@Nuyes
Also, please consider adding listening impressions.
You are correct in pointing out the limitations of non-anechoic measurements. However, measuring THD from nearfield data is generally not advisable.
First, a woofer nearfield measurement cannot represent the entire loudspeaker system. It captures only a single, localized point on the diaphragm, and should only be attempted when the woofer operates pistonic across its entire passband without breakup modes.
Second, even if the first condition is met, measuring only the woofer still cannot represent the system’s overall THD. The far-field response of a loudspeaker is the sum of contributions from its individual drivers, the baffle, and other structural elements—and THD behaves in the same way.
For this reason, I include EHID (Equivalent Input Harmonic Distortion) in my reviews as an alternative. This method, as defined in IEC-60268-21, normalizes the combined transfer function of the microphone, loudspeaker, and room, isolating a relatively pure harmonic distortion ratio. Of course, this assumes the transfer function of the space is perfectly linear, which in practice is never the case—various room modes inevitably introduce small errors.
HI've had the MR4s for 2 years and in my ignorance I think they sound good, now I have them for sale and I'm going for some M-audio BX8 GRAPHITE, A 3-way Edifier with an 8-inch woofer would be perfect for me.
I perform compression tests using a multitone signal. As a result, the relative positions of the loudspeaker, room, and microphone can cause localized measurement errors at certain frequencies.
I have been listening to a variety of music in the last 3 hours. I haven't tried to EQ them yet but so far to my ears, compared to the MR4, the mids sound more detailed the bass is quite nice. This might be obvious if you compare MR4 vs MR5 on paper but it's what stands out for me. Hearing some of those deeper bass tones that i get in headphones but that are missing in the MR4.
How are the mids compared to the MR4? Does the bass drown it out?
It seems like the design compromises are generally well balanced by solid performance. As stated, even with some expected driver integration effects, no significant glaring faults as stated in the review.
For my money, throw in the Bluetooth connectivity and this is a really worthwhile offering.
