Satyadhara
- Joined
- Aug 7, 2020
- Messages
- 40
- Likes
- 15
Hi everyone,
Overall, I'm quite happy with the sound in my room, but there is one issue that I don't quite understand, so maybe you can enlighten me?
My speakers are set up symmetrically, with a distance of 83cm from the side walls, 97cm from the front wall, and 2.10m apart (all measured from the center of the drivers). They are toed in to the listening position by 29 degrees, and I like this setup very much. I have a clear phantom centre, great separation, breadth, and depth. BUT:
- When I listen to voices, especially female voices in movies/series, the "S"-sounds can become sibilant, but only from the left side of the stereo image
- When I listen to music with much echo/reverb, for example a symphony or something recorded in a church, the echo/reverb is also stronger from the left speaker than from the right
I have attached some pictures of my living room as it looks right now. At first, I thought that the record shelf on the left wall would cause this issue due to early reflections, but moving it to the back of the room didn't really make a difference... I should also add that the phantom centre is not affected - it's right in the middle and stays there, as it should be.
Any ideas what is needed to solve this problem? Maybe just some absorbers on the left wall?
Many thanks in advance and greetings from Germany!
