BeeKay
Great to hear it works for you. Enjoy the music! (and avoid the numerous rabbit holes
I know you don’t like your opinion to be discussed…Deeper bass, like a subwoofer was switched on "banging" is the word on my mind, feels physical, not just deep, each bass hit is like a proper hit on my ear drum/head, visceral. Vocals definitely more natural, life like.. Everything blends together nicely. Detailed enough without needing to sound treble hyped.
which tips pls. i have same iem and large ear canalsWhat I can contribute having wide ear canals is how good the tips seal extremely determines how good bass performance is. From no bass at all to pretty darn perfect with the same IEM. I ended up chasing large 3rd party ear tips in Jeff’s Internet 24/7.
With the same 7Hz Zero2 as you.View attachment 418774
@BeeKay posted this earlierwhich tips pls. i have same iem and large ear canals
Similar to the rose technics I just got . Sticky like the azla xelastec but a more standard dome shape .Here another interesting model that reaches fairly wide and short, still reasonably cheap:
Angelears AE100
They also give me the impression to be somewhat sticky, defintely worth trying sooner or later.
hifigo.com
it's me or they just f***ed up the picture?Similar to the rose technics I just got . Sticky like the azla xelastec but a more standard dome shape .
Rose Technics Soundcocoon/SC Liquid Silicone Eartips For Nozzle 4mm-6mm
Buy Rose Technics Soundcocoon/SC Liquid Silicone Eartips For Nozzle 4mm-6mm on HiFiGo, and you can enjoy a year warranty and the best after-sales service.hifigo.com
They did f***ed up the picture!it's me or they just f***ed up the picture?
so this soundcocoon have poor stability while all others are good?![]()
This one lookscorrectmore believable![]()
Although… I still don’t quite understand their point. But it’s probably me![]()
Instead of offering more and more tips choice in every IEM box, maybe the manufacturers should offer a “standard” version of the IEM, with a cheap cable, and a set of 3 cheap S/M/L tips, and a “geek” version, with no cable, and no tips?As an aside , what does anyone do with all the wrong sized tips you collect with iem and multi sized sets? Never in a million years would I use a small set yet have hundreds of the buggers rolling around .
Not a bad idea. Give me a sturdy case and the buds and I'm done. Cant see the makers going for it though unless they want to play the eco card.Instead of offering more and more tips choice in every IEM box, maybe the manufacturers should offer a “standard” version of the IEM, with a cheap cable, and a set of 3 cheap S/M/L tips, and a “geek” version, with no cable, and no tips?
Reminds me of what happened to make the USB-C connector, the standard on mobile phones in Europe, and the mighty Apple Inc, had no choice but to comply. Now you buy a smartphone and it does not come with a charger. It did take a while to happen.Instead of offering more and more tips choice in every IEM box, maybe the manufacturers should offer a “standard” version of the IEM, with a cheap cable, and a set of 3 cheap S/M/L tips, and a “geek” version, with no cable, and no tips?
Especially if they have to include cables with the damn 90° angled 2 pin connectorsInstead of offering more and more tips choice in every IEM box, maybe the manufacturers should offer a “standard” version of the IEM, with a cheap cable, and a set of 3 cheap S/M/L tips, and a “geek” version, with no cable, and no tips?
lol, it became the iem rant thread.That! and also I don't understand the "unboxing experience" put the dammed things in a small plain box.
Going on like this at some point we'll complain having drivers into our iems![]()
You eviscerated them, how brutal!Lol! To stay on topic for a bit at least.
I ordered this ones just out of curiosity knowing they were going to be crappy, they are a bit rigid but after taking out the foam they are not bad at all they fit my ears well, the tip has more or less the shape and bore size of the KBear07, I've been using it for outdoors and because it's a bit more rigid it feels more stable while walking with heavier IEMs.
If we want to talk about crappy tips, i can point out these two i got some months ago, in my search of the hidden jewel among large tips...
https://it.aliexpress.com/item/10050esabmle others06037313058.html
they are strange, they feels not bad at touch and seem standard shaped but no matter the iem i tested them on, no way of getting that right feeling in the ear, no rotation, no pressing, nothing can make them give even a small hint to seal the ears...
https://it.aliexpress.com/item/1005005590722090.html
I tried them because they resembled other no brand tips i got years ago and that turned out to be the only one i can use with Zero:Red in place of the stock ones without fr alterations. Well, these are absolutely no match, the dome is thin and filmsy at the point of making no resistance in the ears, deforming and so, again, no trace of minimal seal.
Stay away from both.
They most likely tried to copy the marketing material for the Divinus Velvet wide bore:They did f***ed up the picture!
Although… I still don’t quite understand their point about the center of gravity. But it’s probably me![]()
Thinking about it, and how ridiculous it can be…As an aside , what does anyone do with all the wrong sized tips you collect with iem and multi sized sets? Never in a million years would I use a small set yet have hundreds of the buggers rolling around .
