- Joined
- Jun 19, 2018
- Messages
- 6,652
- Likes
- 9,520
Hmm, I didn't really get that impression. My impression of what he normally means 'narrow' are large horns, and he has the historical impression of a time when they were more common, probably.
"In those days the powerful main monitor loudspeakers were moderately directional mid- and high-frequency horns, and side walls were usually angled to direct the residual first lateral reflections into the broadband back wall absorber. Recording engineers preferred to be in a strong direct sound field, and that is what they got."
(Talking about recording control rooms)"On the more distant loudspeakers some directional control is desirable to deliver sound to the listening area, not the room boundaries. Horns are common. "
"In Figure 18.3a a classic large horn loudspeaker exhibits evidence of acoustical interference and high directivity, both typical of the genre, but the underlying spectral balance was well maintained on and off axis."
He also implies a few times that the spin is mostly meant to deal with conventional forward-firing speakers, so it doesn't make much sense that he'd be talking about dipoles otherwise.
"Examples in this book have emphasized loudspeakers of the most common configuration: forward firing cone/ dome or cone/ horn. It needs to be asked: What about other designs, like dipoles, bipoles, and omnidirectional? Do the rules change?"
Toole, Floyd E.. Sound Reproduction (Audio Engineering Society Presents) (p. 346). Taylor and Francis. Kindle Edition.
That said, I don't totally disagree with you. Most of what's tested here would probably be on the 'wider' side. The question then becomes what's optimal for most people.
Fair reading
There, he characterises the Rega Model 3 and the KEF 105.2 as "wider" and the Quad ESL63 as "narrow". For example:
In these tests a loudspeaker with narrower dispersion, but with more uniform output off-axis, was given lower ratings than two loudspeakers with wider dispersion, but uneven output off-axis, suggesting that some amount of laterally reflected energy is desirable, even if it is spectrally distorted.
The radiation patterns of these speakers are given:
I'd call the Rega and the KEF, which Toole refers to here as "wider", about "average" by ASR standards. I'd call the Quad narrow by any standard (ofc, given that it's a panel speaker).
I totally agree with you that he seems to characterise larger horns as "narrow", too.
Just not so sure some of the speakers we tend to call "narrow" around here are "narrow" in the sense that Toole means when he uses the word.
