Earfun AirPro 4 TWS Impressions and Measurements
Jeromeof
Ireland
I have been looking for feature rich but well tuned and measuring TWS set for a while. So finally with the Earfun AirPro 4 I thought this was a good enough TWS to deserve a thread on ASR. I previously bought the Earfun Wave Pro headphones and I really liked what this company were trying to do with that Headphone, i.e. use Audio Science to tune their default sound signature as close to Harman and as you will see this trend has continued with the Air Pro 4.
I bought this TWS from Amazon.co.uk but I believe it roughly $70 with typical discounts on the US amazon also.
I won't get into the 'features', but this is an extremely (for the price) feature rich TWS, with mostly everything you could want from sub $100 TWS, wireless charging, AptX Loseless, LDAC Multi-point connections, Auracast (which probably deserves its own post on ASR) and lots of other things but lets get onto the measurements
Earfun AirPro 4 Measurements
Note: All these measurements were taken with my 711 'clone' coupler and are available on my 'blog' here .
Lets start with the frequency response for the default out of the box profile:
As you can see this very closely matches Harman especially in the bass and midrange, the treble could do with a little tweaking which I ultimately did with the built in EQ though any treble EQ beyond 8K will be very subjective IMO.
The channel balance isn't too bad:
The distortion is pretty good considering this is capture at 95db:
As a percentage:
The Group Delay looks ok also:
But since there are lots of sound options to measure, I thought it might be useful for people if I present the various sound profiles.
So first here are the 'simpler' profiles i.e. Bass boost 1 etc compared to 'Harman' in black:
But there are lots of other presents like 'Rock' or 'Classical' which I also measured - though one criticism I would have is these are not different enough:
Here are the most distinct ones on my DB but they are really just subtle variations on Harman:
So as well as the 'profiles' there is also a 10 band EQ which I thought might be useful to measure for its max and min values:
One thing I did find was each band of EQ was much wider than I would have hoped so a change to one does affect neighbouring band significantly, for example the minimal value for 125Hz does pull down a significant range:
So I did decide to use the built-in EQ to see how I would 'fix' the 1.5K to 3K boosted midrange (which subjectively I actually quiet like) but here is what I did I also boosted the treble region to move it close to the harman curve:
For those interested this was this setting inside the Earfun 'Companion' Mobile app:
While obviously you can EQ these separately in your own playback / EQ app, as someone who uses many computers and many headphones, IEM and TWS, if I can EQ the actual device it is as a huge benefit to me, so this TWS starting so close to Harman and then only needing some minor tweaks is great especially at the price, but I would love these manufacturers to starting including PEQ filters similar to what we are starting to see from some usb-c cables and dongles.
Anyway some final measurements, since this is a TWS I thought it would be relevant to measure any audible differences between the various ANC and Transparency/Ambient modes.
Note: I was measuring these in a quiet room so obviously there isn't going to be a dramatic difference.
First the ambient modes which only have a minor difference:
And the App offers 5 different ANC modes:
Not sure why the 'Balanced' ANC mode has a sub-bass roll off but I did measure this a few times and each time it had this response. Mostly the ANC seems to introduce a slight lower midrange 'bump'.
So, I won't get into subjective opinions other than immediately listening to these (before I measured them) they sounded correct and better than I expected and since I ended up destroying my AirPods Pro in a washing machine these will be my daily driver TWS, though the noise suppression with the microphone isn't as good as the flagship models I have tried.
I just bought a pair of these so it was great to find that someone has actually measured them, tried all the different settings, and offered an opinion based on measurements and experience rather than advertising dollars or clicks, so thank you!
Before receiving them I'd already installed the Earfun app from Google Play onto my Samsung A52s 5G (aptX adaptive and LDAC capable). The first thing on connecting was to be invited to update the firmware to the latest version, which I did. It took a few minutes but worked OK. I played around with them to get familiar with the touch controls and check out the various noise cancelling options. I also tried your EQ suggestion. I suspect that firmware updates since your measurements may have altered the tonal balance as I find that with no EQ the earbuds sound great, very similar in tone to my other Harman compliant IEMs and headphones such as Truthear Zero Red, Tanchjim Zero (wired, not dsp), Sennheiser/Drop HD6xx and so on. With the EQ you suggest I experienced a very splashy, overemphasised upper midrange and treble. I switched the EQ off and the earbuds sounded great again. I am not criticising your measurements! I really appreciate when people measure things properly like you did. But, as stated earlier, I suspect that the recent firmware updates modified audio response as well as performing bug fixes or function enhancements.
Some comments on using these: I thought the aptX options are pretty good in terms of audio quality, and are certainly impressive in terms of range - you can walk a long way from the bluetooth transmitter without issue. I am 58 and until a few years ago had excellent hearing (had a job where it was measured) but now have a bit of tinnitus. I did not think I'd notice much or any difference between codecs, assuming the tinnitus would kill any difference. But when I got these working with LDAC I realised I am not yet deaf! The difference is pronounced and these wireless buds now sound like my very nice wired IEMs and headphones.
Another really nice discovery was that once I'd set up LDAC via Samsung's Bluetooth settings then these earbuds also connected using LDAC to my PC's very unremarkable USB bluetooth dongle https://www.amazon.co.uk/dp/B098J5XX5G I had no idea this dongle supported LDAC, it's not specified or advertised as such, but it does. The LDAC support did not show until I'd already set up the buds with LDAC on my phone. I'm going to buy another for my (very) ancient Thinkpad T420 laptop!
Sorry for the delay but I finally got the Air Pro 4+ and spent a few hours doing measurements this evening:
This is basically all the EQ profiles and the min / max of the custom EQ and some measurements of the different ANC modes. The one weird one is the 'Default' Ambient mode ( I thought it might be defective but both the L and R do this very weird dip in the sub-bass). the 'Natural Ambient' is fine.
But I guess you want to know what the default or NoEQ option looks like against Harman and the previous AirPro4:
I do have a weird channel match issue in the bass region ( subjective I can hear this also listening to the Tone Gen App one channel has louder sub-bass than the other).
The ANC and Ambient 'Natural' modes are all thankfully very similar also just a slight midrange and sub-bass difference:
I will write up a detailed review in the next week or so but mostly I think this is a better TWS and a subtle but decent upgrade over the previous generation. The ANC for actual noise cancellation is a little better but still not at AirPods level and it is still a pity we don't have PEQ in the Mobile app but this is one of the few TWS and one of the few companies that sell 'consumer' ANC products but tune them to close Harman, so in general they don't need much PEQ.
I have found this one to be their best ( fit, comfort, features ) and I think it does sound slightly better, so there is almost nothing to complain about except that weird 'Ambient default' measurement and they have change the ear tip style to oval which slightly limits the third party ear tips.
I will try and get these measurement onto my website in the next few days but it takes a bit of time and get a proper review published soon.
Both the regular 4 and the 4+ actually support parametric EQ, it's just that the app uses hardcoded values for the frequencies (shown), Q (0.7) and filter type (peaking). Actually, for the regular 4, the payload sent by the app doesn't include a filter type at all, so either their firmware can only use peaking filters or it's just omitted for brevity and it can be specified optionally – I can't test this myself, since I only own the 4+.
I threw together a web UI for configuring the parametric EQ on the 4+ here. IIRC, adapting it to the regular 4 should be trivial by just removing the filter type from the payload, but to be sure you can check the Gadgetbridge code here or, if you have an Android phone, looking at the logcat output when setting the EQ via the app (as it logs everything that it sends).
That's the very definition of digital Graphic EQ (multiple Peaking filters with fixed frequency and Q).
The in-app UI is a graphic EQ, yes, but the actual data sent by the app and processed by the TWS is parametric. As opposed to other devices where the app only sends the gain values and the rest is hardcoded in the device.
If frequency and gain are fixed anyway, then what point would there be in sending frequency and Q data to the headphone?
In the end, the result is the same: graphic EQ.
I've been using a pair of the AirPro 4s on my (almost) daily circumnavigation of Prospect Park in Brooklyn and I am very impressed with their sound (after playing with the EQ), the efficacy of the noise cancelling function and their general functionality as far as taking phone calls, etc. However, I've been most disappointed with the Bluetooth reception when passing cellphone users, etc. Is the garbling and dropouts normal for such devices when used in crowded urban areas? Would a pair of new Apple Airpod Pro 3's perform any better in that regard? Please advise.
I've had a pair of these for six months and have been fairly impressed by them for the price (I paid $55). I use them with a Hiby M300 portable DAP but generally only use them when I'm traveling or stuck out somewhere for a couple of hours or more. Good sound, and very comfortable. No issues so far with interference from phones or other Bluetooth devices. If you want a pair of wireless IEMs and don't want to spend a lot of bucks, these are a great option.
