Hello everyone.
I have not used the amp for years so decided to sell it. The chap who bought it complained of an audible hum from both speakers and he returned the amp for a refund.
The year of manufacture is 1986. The amp has a gain control and a MC / MM switch. The hum increases as the gain is increased. Inputs short circuited.
According to a spectrum analyzer app on a phone the frequency emitted by my speakers is 50Hz which is the UK mains frequency.
I decided to change all the electrolytics. The circuit diagram that came with the amp showed different values to those actually fitted so I messaged Ear Yashino for advice. The engineer replied suggesting the following values to use. C8 100uf 200v. C9 & C10 47uf 400v. C11& C12 100uf 200v. C13 & C142200uf 35v. I also changed C 101 & C106 for 100uf Elna silmics. N.B. C106 is denoted as C6 on the diagram. C101 is the corresponding capacitor for the left. channel.
The hum diminished but it was still audible. As suggested in a forum discussing a similar problem which I can not now find I fitted new Sovtek 12AX7WA tubes to reduce the gain slightly. The hum is now much less but I can still hear it when the gain is on max and my Benchmark pre and power amps are turned well up. Using a DMM I could see what appears to be a 50Hz frequency on the heater suppliy.
One strange thing is that if I remove the top cover from the Ear (just a flat metal sheet) the hum reduces, Tried earthing the cover to the single earth point on the rear but no changeI can not find out if
this level of hum is normal for the Ear / Benchmark combination. Should I just have a hiss from the Ear or would you expect a hum at these levels.
I want to sell the amp again but I am not confident that it is fixed.
Help please. Alan.
Help please. Alan.
