E30 not providing anything over .700V
The OP thinks the DAC doesn't produce enough output for the amp, which is a reasonable concern that justifies a multimeter.
Something in that chain isn't at full output. The game is afoot!
Is the iPad volume at max on the second video? Is the test being generated at 0db? It's hard to see.. Also lower the frequency to 200-300 Hz, your DMM is spec'd to 400 Hz.
give me a few. That was the direct link given earlier, yes ipad at full volume..
I wonder if there's any volume limiting going on with the iPad. That would translate to 100% volume not being 0dB. However, seeing a lower output voltage when playing music is completely normal, as no song has a constant 0dB level, which is why using test tones is necessary.
I don't think we've yet seen any positive confirmation a 0db signal is being used for this test.
I really do hope it's on the input side. Ain't nobody wants to find out either I devices can't output full strength or a popular dac has issues.
IDK man!! Just isn't feeling like I'm getting what was intended in terms of power / punch..
Direct me.. What about the music? Never gets over .7 Volts, Ever.... Can I get at least a volt, variable? lol
Do you have another DAC you can test with the same input signal?
Michael
I dont sir.... This is my 3rd,(other 2 where not tested) Amazon has been very nice in the return area through this whole adventure.... Headphones, amps, dacs, lol, waiting for them to ban me.....
Can you do a PC > USB connection > E30, use Foobar with WASAPI installed, generate the test tone @0dB @16/44.1 then take some measurements?
Can you do a PC > USB connection > E30, use Foobar with WASAPI installed, generate the test tone @0dB @16/44.1 then take some measurements?[/QUOTE
PC netted same results. Regardless of test tone or music, it was the same results..... Did not use any altering / refining apps.. Did exactly as I have shown with the Ipad.. IDK.. Even in a perfect situation tone / 0db, it still doesn't change the fact that The variable (Music) side is what the system is intended for..
Just play music like normal. Turn up the amplifier if needed. Music normally has much lower RMS level. So it's all good.
Rather find a source to provide a stronger signal... Signal is where it starts..
