E1DA Cosmos ADCiso
Now we talking Guys ;)
Settings REW:
Extractor HDMI to AES ---> SU-2 ---> COSMOS SCALER --> ADC DM 0,5dB FS:
Bad Jitter clearly visable, still THD+N @ -114dB!!!
Extractor HDMI to AES ---> MUTEC MC-4 AES (48kHz) to AES (48kHz no SRC) --> SU-2 AES to XLR---> COSMOS SCALER --> ADC DM 0,5dB FS:
ClockDelta 3.9 ppm
THD+N 120dB measured without an Notchfilter (APU) driven by HDMI!!!!
The Same with Notchfilter (APU):
THD+N -122dB measured with an Notchfilter (APU) driven by HDMI!!!!
So now we talking ;)
Next is to integrade the RME HDSPE AES Card with CamilaDSP!!!
COSMOS SCALER and ADC DM rocks now ;) buy both together, Tip of the Day!!!
Crazy Testbench:
Used an USB A to 4x USB C Cable from powerbank ;) (a bit short, sure)
Yeah Windows kepping beeing a bitch ......
Now with Motu again no chance to measure with COSMOS at the same time with ASIO or JAVA EXCL Driver.....!!!
Lost in Windwos COSMOS i would say LOOOOL
SO the only chance now using my HDMI to AES Extractor.....
Like I said, you can run two instances of REW, one acting as the generator with the Motu and its ASIO driver, and the other for the Cosmos with Java driver.
Else buy a simple DDC like the SMSL PO100 Pro, no brainer.
Yeah, but i realy like to use USB to AES EBU then, because the RME Card also uses AES in and Out so i gues for now i need to wait to an QA404 with AES in and Out or i could buy this thing or anything like this:
https://www.thomann.de/de/yellowtec_puc2_lite.htm
or
https://www.thomann.de/de/mutec_mc1.2_silver.htm
https://www.thomann.de/de/mutec_mc_3_smart_clock_usb_silver.htm
or DYI with Anamero USB Board
https://www.audiophonics.fr/en/inte...l-interface-usb-384khz-to-i2s-dsd-p-7403.html
with
https://www.audiophonics.fr/en/inte...al-interface-32bit-384khz-dsd128-p-13627.html
for 105€ + 5V Powersupply
I have already this Board (for feeding all digital kind of Stereo Connections into RME HDSPe AES Card as addition to HDMI 7.1):
https://www.audiophonics.fr/en/inte...nterface-module-ak4118-bluetooth-p-18770.html
It has also the possability to use the Anamero Board instead of BlueTooth and connect it to that 30€ i2S to AES Board above so you has all you need USB, SPDIF, AES and Toslink in and SPDIF, AES, i2S and Toslink Out for less than 200€
Anyway i will do the test with MOTU and 2 REW Instances next day ;)
Just picked up one of these, but can't seem to get my laptop to play well with it. In particular, it doesn't seem to get a signal from my processor. I have the left and right XLR outs of my processor (AT-600) connected to the XLR ins and adjusted the dip switches to row 3.
I can select the Cosmos as the Mic/input device, and my processor as the Output device. Nothing is muted. Shows up fine in Device Manager (no exclamation point).
But whether I try Phonalyser, or simply run a 1khz tone say through a website (Ronter sound), nothing gets captured. I know the AT-600 is getting a signal from the HDMI out on my laptop as if I use the same XLR cable but connect it to my speaker, the tone comes through just fine.
Have checked to make sure no processing is on on the laptop, nothing is muted, etc. Any ideas? Tried about 3 hours of troubleshooting with Chatgpt to no avail!
COSMOS ADC DM has 2 USB-C In
You need to plug HDMI LOOOL i mean USB-C on Power IN first and after that, connect USB (PC Communication) to USB IN on COSMOS ADC!
An orange LED goes On than, USB (Communication), you need to wait till it is Blinking than it is ready to use!
I had the Problem every Time if i switch on my Powerbank and the USB to PC was already connected, it didn't worked i have to reconnect the Connection to PC after Power was already on!
Using an Powerbank as PSU.
REW was not recording anything till i reconnect this USB-C to PC!
It is a bit Strange and i don't like it but the Webpage says it also!!!
First Power than Communication to connect!
When i left my PC for longer Time after mesasuring and i come back REW was alread again not recording need again to reconnect the Communication USB-C Connector and it works again.
Need to investigate it, probably need to deaktivate this Powersave thing on USB (Windows 10)
"Power efficiency Diagnostic" i had already deaktivated so i am a bit confused why COSMOS ADC stop recording after longer Time doing nothing with Screen went Black and so on "Screen Powersaving mode"
Also you can see if an Signal goes to ADC DM, there are tiny LED'S below the XLR connector, they light up green and if it is clipping they wen't Red!
I had the same Expirience using it the first Time, searching why it don't wan't record anything after checking al kind off Settings on Windows Soundsetting Page!
For REW it shouldn't be the defoult recording Device, you can select it in REW, on youre Software i don't know.
Reactions: pbc
Tested this day using 2 REW Instances with MOTU ASIO Driver for Generator and COSMOS ADC DM on second REW for recording, works very well :)
Measuring SU-2 at MOTU SPDIF Out, clean as Hell ;) (APU (Notch 1kHz), Scaler and ADC DM at 9,5VRms Switch position):
This is with the processor at -5db...diff between in and out constantly at about 20db. Getting a green light at least,
Seeing a similar issue in Phonalyser. The voltage reading it gives when reading the Cosmos is way lower than my Fluke Meter or O-scope direct from the processor using the same test tone. E.g., at -20db on a 1khz tune from Phonalyser it reads only 18.2mV vs 1.07 on the Fluke from a cable connected to the Left or Right channel (after unplugging the Cosmos). Maybe the dip switches are incorrect that I'm using (set to 1.66)?
1.66k is the input voltage of one XLR input of the Cosmos DM (4.4Vrms setting).
If REW reads -27dBFS at the input, in that setting, it means the analog output of your device is a low 0.2Vrms or so.
If your processor is at -5dB and you send a -6dBFS into it (as I see from the REW printscreen you posted), then the output is attenuated by -11dB. If the standard output is 1Vrms, then you’re at 0.27Vrms, so it looks ok.
What is the max output voltage of the device you’re testing?
Thanks for the response! Below is what I measured.
Should note the below was with a Blu-ray Disc via HDMI into the AT-600 processor with a 1khz tone. Above comments are via the laptop and Phonalzers 1khz tone.
Front Right XLR​
Test: Track 5, 1 kHz tone.
Master volumeVrmsVppWaveform
−20 dB0.11 V0.32 VClean
−15 dB0.19 V0.55 VClean
0 dB1.05 V2.97 VClean-looking
If that track is at 0dBFS then you have 1Vrms at the output of your DAC, unless there’s another volume attenuation with the DAC (you said -5dBFS?).
That was measured on one conductor, so 2.1v. Should I change the dip switches to the 2/9.1k setting?
Also what is the difference between the two dip switch settings that both say 2/9.1? Ie 4th row and last row on the Cosmos?
The numbers on the left represent the balanced differential input impedance values, in kilo-ohms, of the XLR and 2.5 mm TRRS AUX connectors, respectively.
The numbers on the right represent the balanced differential RMS voltage required to reach an input level of -0.5 dBFS for the XLR and 2.5 mm TRRS AUX connectors, respectively.
Note that Cosmos ADC input impedance is very low and would be even lower for unbalanced connection which might load and affect measurement of poor sources with poor current drive and/or very high output impedance.
BTW if you want to get accurate voltage measurements using Cosmos ADC you would need to prepare 0 dBFS calibration for each input sensitivity setting in REW.
Thanks. My thick skull is still confused.
I measured 1.07 Vrms using my Fluke.
At row 3 sensitivity, that should produce approximately −4.3 dBFS on the Cosmos I would think?
But I’m seeing substantially lower digital levels?
Measurement Actual Expected Difference
Phonalyser FFT (1 kHz) −39.4 dBFS −4.3 dBFS −35.1 dB
REW input level −27.4 dBFS −4.3 dBFS −23.1 dB
So something is up somewhere in the chain I would think? Was a 60hz 0db tune.
Clearly I’m misunderstanding something somewhere!
1. Set all volume levels on your hardware to 100% / 0 dBFS
2. Calibrate Generator "FS sine Vrms" in REW according to instructions
3. Calibrate Input "FS sine Vrms" in REW according to instructions
Remember to measure voltage differentially between XLR pin 2 and 3 using DMM.
Reactions: pbc
Crucially, measure the signal generator's output voltage while its output is loaded down by the Cosmos ADC.
How do you do that specifically?
Typically using a breakout board, but it depends on the type of connector on either side of the connection.
Alternatively, you can research/measure your signal generator's output impedance, and calculate the voltage drop.
Could I use these, connect one end to the processor out, other end to the Cosmos, then connect each of the pins using say stranded wire and measure the load that way
(measure it unloaded then loaded)?
