Alright, if your DUT has noise(the THD component is far from that level -137db, so we'll omite that) -126db, and ADC as well -126db, the result should be 3db worse i.e. -123db. Hence, your DM THD+N = -126db. So, what is your verdict? Is DM grade B better than ADCiso grade 0?
Hi Ivan, sorry I never replied to your question.
For the way I've been using the ISO, that is with 10V input and the scaler in front, to measure high res DAC at 4Vrms output, and meaning I increase the gain by 7dB, I think yes.
For instance this is the ISO (in mono mode) measuring the SMSL DO400 (no APU notch here):
Now the same with the Cosmos DM in stereo mode:
It's logically almost identical.
Now if I use the virtual balanced mode of REW, therefore using both inputs of the Cosmos DM Grade B, then I get:
That's indeed better.
Anyways, worst case scenario, the Cosmos DM can report the same performance as the AP of Amir, because the SMSL DO400 I used for these tests is the one that Amir reviewed
here (I bought it back from him). And this is without using a notch, meaning it's really interesting performance when it comes to run high precision sweeps.
The DM Grade B in virtual (REW) balanced mode beats the ISO Grade 0 in that particular case, but also when set at other input voltages, eg here below:
