- Joined
- May 15, 2019
- Messages
- 1,087
- Likes
- 4,567
I did not 'built' this. The unit used by EUVL and described in my pdf is the Autoranger, designed by Jan Didden, published in the DIY forum. I used that unit myself and wrote a technical review about it which explains its functions, tech specs and some limits. Jan liked my text so much that he added it as additional info to the offical (his) manual and website.I recommend this solution:
Installing the E1DA Cosmos ADCiso in a larger metal housing - supplemented with these external components, for example:
Self-built preamplifier *1) with switchable input sensitivity (the switch from the ADCiso is only suitable for a few circuits), a stereo/mono switch, external XLR sockets, ...
Internal USB-C socket (control) to external USB-B socket. The power supply (USB-C socket) goes to a built-in lithium battery, which also contains a charging circuit.
Here is a version from EUVL:
... with balanced output for controlling an E1AD ADC via an OPA1622, both in the same housing
The scaler is unsuitable for me without modification:
- cannot attenuate the signal
- too low max. input voltage
*1)
Some time ago @MC_RME built such a preamplifier and presented measurements in conjunction with the - unfortunately no longer available - "Linear Audio AutoRanger ARII Version 3" ("AutoRanger Version 3 Tech Specs MC JD 6c.pdf").
Like other people here (John Young, PMA, KSTR...) I also built myself a preamp (fixed gain only) as small box that allows to amplify low level signals and act as impedance buffer, mainly for noise/SNR measurements. The circuit can be done in different ways but is very easy. One can also use microphone preamps (rja4000) as long as their low input impedance poses no issue.
. In fact I meant Spdif i/o, instead of USB - to be able to clock it externally.
