Neither remasters.High sampling rates are not better: https://people.xiph.org/~xiphmont/demo/neil-young.html
Particularly Cosmos ADC is very well protected. I sold nearly 2000pcs and had just 2-3 cases when users burned the input caps during a poweramp testing(XLR>20Vrms). 1 case when the handmade power supply was used and killed the USB bridge. APU's and Scaler's inputs are protected quite tricky, however, 10-100K Zin is more fragile anyway. Cosmos LPF has a low Zin again, and I believe nobody will complain about its protectionBut the selfprotection of the devices is not state of the art.
Like many times before, ESS datasheet circuits are usually far from optimum. Way to high output impedance at higher frequencies for those 9822 and 9823 final passive output RC filters. Much better is a feedback circuit similar to the one shown for the OPA1633 driving a PCM1804.So, I think we need to test the linearity of 9823 first(especially at 10kHz, after I took a look ESS recommended frontend).
I also suspect it just marketing.how many DIYers want even better and are ready to pay for that?
The last 3% are usually more expensive to develop than the first 97%.well, the paralleling is fine(BTW, 9822 it seems also has some I2S features for that) but cascading, idunno. IMO, it is a 99.99% marketing feature for musicians or others who can't realize that such DR isfakearguable. It's similar to a DSD feature of 9822, it is there but.. made from PCM and what? So, I think we need to test the linearity of 9823 first(especially at 10kHz, after I took a look ESS recommended frontend). I noticed that TD+N specs were done at -1dbfs, and I worry a little. THD+N of a calibrated MONO 9823 is expected to be around 3db better than APx555, how many DIYers want even better and are ready to pay for that?
Can you name one studio mic with 140dB DR or more?A good studio microphone achieves a dynamic range of 140dB. (1uVrms(A) noise to 10Vrms max output)
For example AKG C4000. (Datasheet is on the save side with 137dB but I measured them often enough at my time at AKG, when your preamp has a high enough input impedance you get 140dB dynamic range)Can you name one studio mic with 140dB DR or more?
Yes, this is the whole idea. No more gain adjustment to consider, and still always recordings that are neither clipped (or needlessly compressed if you are lucky) nor noisy.@IamJF, Do you believe that someone in a production studio gonna use the same mic and preamp with the same gain for a jazz vocal and hardrock drums?
What has this to do with the solution to have a wide DR A/D converter? You can use every mic you want with such an input.IamJF, Do you believe that someone in a production studio gonna use the same mic and preamp with the same gain for a jazz vocal and hardrock drums?
Maybe some exotic cases exist, however, we forgot about the splitpoint artefacts. The level where a low-gain ADC is replaced with a high-gain one and vice versa. Did you see how people complained about a short clipping clicks in CS43***, which implemented a similar gain-switching tech? Do you think cascaded ADCs would be flawless?Yes, this is the whole idea. No more gain adjustment to consider, and still always recordings that are neither clipped (or needlessly compressed if you are lucky) nor noisy.
Stacked ADCs are becoming more and more popular, for example in field recorders, and the movie sound crews love it! As do wildlife researchers etc.
It of course all depends on the implementation.Maybe some exotic cases exist, however, we forgot about the splitpoint artefacts. The level where a low-gain ADC is replaced with a high-gain one and vice versa. Did you see how people complained about a short clipping clicks in CS43***, which implemented a similar gain-switching tech? Do you think cascaded ADCs would be flawless?
From the marketing point of view, it makes sense, I agree, but it is not about audio quality.
