And for capture and digitizing Vinyl Records? This E1DA Cosmos ADCiso is better digitizing to DSD, or must I go with the Tascam DA-3000 (digitizing to DSD)?Not really. 90dB SINAD is plenty transparent enough to record great music.
But it's no question which is the better ADC.
Not sure why you would want to digitize vinyl to DSD, but you could also use RME ADI-2 Pro or ADI-2/4 SE Pro. Both can record at DSD256.And for capture and digitizing Vinyl Records? This E1DA Cosmos ADCiso is better digitizing to DSD, or must I go with the Tascam DA-3000 (digitizing to DSD)?
Vinyl has extremely limited fidelity and can be captured in its entirety even with basic ADCs.And for capture and digitizing Vinyl Records? This E1DA Cosmos ADCiso is better digitizing to DSD, or must I go with the Tascam DA-3000 (digitizing to DSD)?
So I am OK with the PCM4202 Burr-Brown (Tascam DA-3000).Vinyl has extremely limited fidelity and can be captured in its entirety even with basic ADCs.
Also, the Cosmos ADCiso cannot digitize to DSD.
I originally meant DSD recording straight from the DSD source from studio recording, and/or AAA All-Analog recordings (from the 60s, or early 70s) whatever from a R2R tape, a Vinyl Record, or Master Tapes. At least DSD128 or higher. If you record audio in PCM from scratch you'll lose impulse response. The key point is to preserve the Analog/DSD impulse response, then converting the DSD capture to Hi-Res PCM. A possible similar lineage method done by MoFi, Analogue Productions and Pink Floyd DSotM 2003 and 2023 Remasters.I've never seen a DAC perform better in DSD, it's always worse than PCM. The best way to accurately record audio is PCM (>96kHz, even 768kHz if you believe in hell), and then if you want to save the audio material in DSD (no reason, but it's up to you) use some software PCM/DSD converter.
I have:I've never seen a DAC perform better in DSD, it's always worse than PCM.
www.audiosciencereview.com
I wish I could do an example but later, not now. And Yes, glad DXD can handle impulse higher than 192kHz.J N L, Could you give an example of impulse response of the analog source like 15 ips tape? With high sampling rate PCM you will be able preserve it. Anyway, sounds like another myth in audio community.
Because they sell mythology.I wish I could do an example but later, not now. And Yes, glad DXD can handle impulse higher than 192kHz.
But I wonder still if DSD is a myth, so why labels like Analogue Productions/Acoustic Sounds and MoFi uses it? And the people who uses it: Bernie Grundman, Ryan K Smith, Rob LoVerde, Krieg Wunderlich, Kevin Gray, etc; and they do AAA lacquer cuts professionally.
Agreed PCM is insanely accurate, but again, you will lose impulse response of the original recording, well at least this is my POV for now.
Seasoned folks used to judge performance by the recorded applause, not instruments for realism.sic.
I found a study about content >20kHz in music instruments a while ago. they looked really hard and actually found a little! I will dig around, maybe I can find it again.
For the effort it took them ... they found VERY little ...
Hey, I was born in Salzburg!Impulse response ... from a needle going through a groove ...
What impulse should there happen?
1st - imagine there is a step in the groove of your LP (=impulse). What would the system do? You barely scratch the 20kHz (normally you don't reach it) - it can't reproduce a step electrical and mechanical.
2nd - there are VERY little instruments which produce content >20kHz! It's pretty hard to find anything up there, when you don't think dangling keys are a musical signal ;-)
Something like a snare hit is a large impulse but not a rectangle. You would need to listen to explosions or starting clappers (which are used for room acoustics, works great for higher frequencies) to have signals with a real step response.
3rd - these comparisons of digital filters and conversions and cables and whatever are often done with VERY unreal signals. Measurement signals.
There ARE differences between filters and conversions and in signal processing it's important to test these and design them right. Therefore you use impulse or square or other signals to show the behaviour or differences. But these are as far as possible from real music signals! You would need to do these measurements with a 20kHz low pass filter (or 17-16kHz for us older folks) BEFORE entering the chain and look at the differences then to get something similar to music.
Instruments have "holes" in their spectrum or better said they only excite some frequencies. Every instrument has some frequency area where it has information/signal and some where it is weak or doesn't play at all.Seasoned folks used to judge performance by the recorded applause, not instruments for realism.
reel to reel tape & Master Tapes (as well as LP's).
At least they're fighting the loudness warBecause they sell mythology.
