E1DA Cosmos ADC
Double ADC chips, 3db up to the DR and 2db better THD+N(better than -127db for grade 0), a bit different frontend makes lower h2(from 8 units no one higher than -150db), and h3 too, especially at 10kHz(-126db). Built-in thermostat, controllable with Tweak_CosmosDM.exe, which got DC control as well. Improved low-frequency jitter, 10Hz and lower.
I’d like a grade 0, please pretty please :p
E1DA is a very small company and we are fortunate to have @IVX participating on ASR.
For the Cosmos A to D they are individually tested and "binned out," separated into performance grades. That takes time.
I am not a fan of the Discord platform, but new E1DA news comes out there before ASR.
I, and many, have E1DA A to D and D to A ordered by their normal channel.
Patience as manufacturing ramps up in a sustainable business way.
I found the first B/0 unit, and as promised, B chip was replaced with another 0 chip. So, we got the first grade 0 DM. Rch harmonics stellar! Lch just ok.
Another unit from my bench. Due to DM using 2 9822 chips, the final harmonics distribution is never the same for L and R channels. Anyway, the new frontend is cleaner, I never saw THD -143db with ADCiso.
Another channel isn't stellar again:
Hence, to get a perfect combo of noise and harmonics for L and R simultaneously, you really need to select 2 chips from 20-50pcs.
That’s a massive sorting job! Do you have a test bench for quickly checking them?
It would be simpler if the company tested and graded them in-house during production, as was the case with parallel DAC chips.
Hello everyone! This is my first time on this forum and I would like to become an active participant. But for this, I lack the least - to buy the Cosmos ADC. Is it possible? Or should I finally give up trying to buy this device? It hasn't been on AliExpress for a time.
Cosmos ADC is an obsolete model from 2021(only a second-hand), the next was Cosmos ADCiso 2023, and Cosmos ADC DM in 2026(available).
Ivan, I tried to buy the dm but it’s not available at the aliexpress store. Where else can I buy one?
Edit: managed to order a bundle 3
Grade A with the scaler. Thanks
Thank you for your response.
I am encouraged by the note "available", but I join dlovemusic's question: where and how can I buy this device.
Best regards.
We've been selling DM for a couple of weeks, but we've already got 2 "bad units". The first one was reported by a Chinese user, he didn't let the device warm up, and decided that the noise level too high. Next, he changed my calibration coefficients and got DR 100db(A) instead of 130.7db(A). Fortunately, I live 40 km away and got the unit the next day, recalibrated it again - no problem.
The second case with a Korean user. He complained that the ADC completely doesn't work, asked for a money-back, and sent pics where there is only one USB cable plugged into the ADC i.e. the ADC isn't powered On.
Guys, please read a little about the product before you buy it.
Our Cosmos DM user made some tests and found that all his USB-A2USB-C cables work steadily and stably with Mac, however, USB-C2USB-C aren't! He kindly sent me the link to the stable, inexpensive cable https://www.amazon.com/dp/B01GGKYZQM?th=1
Ivan, I am currently just powering the Scaler and ADC DM with some 5v3a phone chargers. Would you recommend some stable power adapters?
Cheers
In most cases iphone/adroid adapters are fine. If you suspect the results of your tests, try a power bank.
Thanks. I am not looking for anything too fancy just thought something like the CUI medical grade power supply for $30 might be a bit more reliable for lower noise/current leaks…
