E1DA Cosmos ADC
Thanks for the answer... so if Wolf BP filtered the ADC output signal, he would have gotten the above result, correct?
Rather like this:
A linearity test is an archaic way to test ADC, maybe for 8-12bits is ok, .5db corresponds 5% of THD. THD vs level sweep is much more sensitive. Linearity+N has no sense to me.
Excuse my language barrier...
I just wanted to be sure that the differences were so small, It wasn't due to a very low number of harmonics being considered in the THD measurement (I believe it's generally considered up to h9).
(But also, only displaying h2 isn't very useful... you need at least up to h5 or h7... even and odd harmonics.)
(Maybe observing the chemical capacitors bypassed by an small MKP or better yet a styroflex or Teflon would be funny.)
I think the mentioned low.freq effect is shown here https://www.audiosciencereview.com/forum/index.php?threads/smsl-do300-dac-review.43780/post-1915440
Suppose it was an unbalanced connection, a balanced one has H3 -110db i.e. no effect. Anyway, 9822, and 9823 also have some hump of THD at < 100 Hz and 0dbfs. My test was performed at -6dbfs level to see -120db of THD, -.5dbfs test shows -110db of THD.
Sorry if my question is not new. Where will be DM version available to order? In DD-Audio Store?
@IVX I have Cosmos ADC iso since maybe two years. But after I think overvoltage glitch on the left channel I have now strengt behavior. Left channel has huge DC offset about +0.5V, but seems to work, on the right channel - no signal as expected. If I connect signal to the right channel - right channel works as desired, left channel shows always same signal but -6dB from the right. Maybe has you some idea what can be broken? It will be bad if ADC...
Sounds like your Cosmos is in Mono mode:
You can change modes via Cosmos Tweak utility (Windows only) and via UAC2 hardware volume level (OS agnostic).
Edit:
The clipping LED on the face plate also reports modes:
Blue=Mono, Green=Stereo.
I think Static is right, MONO/STEREO mode was switched. However, if you really see DC over there, I suspect the input aluminum capacitor (220u/16V) has some leakage. It's not a big deal to replace.
Double ADC chips, 3db up to the DR and 2db better THD+N(better than -127db for grade 0), a bit different frontend makes lower h2(from 8 units no one higher than -150db), and h3 too, especially at 10kHz(-126db). Built-in thermostat, controllable with Tweak_CosmosDM.exe, which got DC control as well. Improved low-frequency jitter, 10Hz and lower.
thanks, sounds very good, will order later
With ADCiso (i have it) what happens if you make a mistake and don't power first? Plugging in the data port can cause damange ?
No problem, it is safe. BTW, DM doesn't require a specific order of USB plugs, but "Power first" is preferable.
Pricing?
Our primary internet provider refuses to let me connect to the wixsite address due to unspecified security reasons. Our secondary one used for the phone will allow me to see the main E1DA web page, but refuses to allow direct Aliexpress connection. The aliexpress.us site doesn't show any Cosmos ADC's. :(
You may use a VPN or simply TOR Browser, not?
VPN possibly, but for something I can directly ask Ivan, why? Browser doesn't matter.
