Hi,
I am using an ADAU 1452 evaluation board from Analog Devices for my active speakers, which I really like because of the endless possibilites by the use of Sigma Studio.
The only drawback is that it is using an AD1938 codec on board for the analog outputs. With 108 dB DAC dynamic range and -94 dB THD+N performance could be better, though it is not problem in my current application. As input I use the SPDIF Input, therefore the ADC performance does not matter.
I am thinking of improving the DAC performance by using I2S to balanced analog out DAC PCB. To ensure that this combination is really better, I would like to measure the current performance and that of a potential replacement.
Therefore I bought the Cosmos ADCiso and have some question after my first trials. I am using balanced outputs with nominal 2 Vrms out for 0 dBFS. I measured it with an multimeter and the reading showed 1,78 Vrms, which should be correct, just 1 dB out of spec.
On the ADCiso I choose 2.7 V input setting and 1K ohm impedance. I connected the XLR cable to the left input only and the device is running in mono mode.
My first measurement of the spectrum looked like this.
I was surprised by a few things:
- Level should be higher than -10.73 dBFS
- THD is about 10 dB lower than spec of the pure codec
- SNR is 9 dB lower than spec of the pure codec (108 + 3 =111 because of balanced use)
After this I changed the input setting of the ADCiso to 4.5 volt and 1.66 K ohm impedance with the following result.
The level dropped more or less as expected. The SNR is 0.5 dB worse, but the THD improved by 9 dB (now in spec), which I did not expect. This means that already two things are different than expected, the too low level and the THD improvement with lower sensitivity of the ADCiso.
I started to measure the frequency response for 2.7 V input setting.
The low frequency rolloff was not there, when I measured it with an RME Interface and I decided to measure it for all sensitivities of the ADCiso.
As you can see the rolloff towards lower frequencies is dependent on the ADCiso input setting. I remembered that Amir has written, that the low input impedance of the ADCiso could be a problem for some devices.
Do you think that this could explain the low level and the strange THD behaviour as well? Would it help, if I would use a E1DA Cosmos Scaler in front?
Thank you!
